Honestly not in a way that matters. if your playing at 1920x1200 or below your still going to push over 60 fps regardless and if your playin on a 30 inch or a multi monitor setup your GPU won't be able to feed your CPU enough data to even begin to keep it busy. sure maybe with a faster cpu you could push 200 fps in older titles instead of 150fps but really you will never see those extra frames so it doesn't matter.
you'll never see over 120fps at any resolution with a 120mhz monitor.
I'd assume by see that he actually meant see.Depends on what you mean by see.
Probably not, but that GTX590 catching fire might bottleneck your CPU
Sorry, couldnt resist
Exactly.
That's a legit concern. Honestly I think the GTX 590 is a bad buy. The GPUs are too gimpy (referring to their clocks) and the thermal solution seems inadequate.
Wait until DD or someone has a full coverage block...then play with the card.
However, the offending cards were being overvolted by large amounts...
Na bro you're processor is good. Just make sure you oc that baby to at least 4Ghz.
Some of you guys are way too caught up in upgrades.![]()
Stock cards are dying all of the place as well. If the circuitry sucks, the circuitry sucks. Changing the cooler won't help that much (running the card at lower temperatures will save some watts, but not anything significant).Wait until DD or someone has a full coverage block...then play with the card.
It's a serious addiction
