In my case on a 955BE C3 and M5A99X EVO board(AM3+ the chip is the one that controls the memory not the board) 1066/1333/1600 works flawlessly, however the 1866+ doesnt seem to like to stay stable.
in my case, yes for the moment, I have tried putting it to 1866 and was not stable, though I have not put it back there for the moment as I overclock and am trying to find the highest clock I can get cpu side first.
The memory limitation seems to be focused around the core clock. If you are at stock clocks on the cpu then 1600 seems to be the limit, overclocked, well that seems to depend on the cpu more then anything else, the IMC can only go +/- so much. I have read others not having any issues using thier memory 1866 or even at ddr3 2000 speeds, so I do not know.
Offically, ddr3 1066 is a default, 1333 is thie highest step, 1600 supported through overclocking, 1866+ is luck well this is according to AMD AM3 chips which are the Athlon II and Phenom II chips. AM3+ being FX and A series chips thier limitation seems to be well above the 2000 mark.
