And this will be in a Lanbox case in which I know it's ok for the height.
What's the original E4300 heatsink height so I can compare just by looking into the case?
I know I have to order the LGA775 bracket but which fan do you recommend? Not a killer one, a silent one with either 4 pins or manually variable.
Or any other recommendation? I know almost anything will be better than the original Intel heatsink but I don't want to spend 100$ on a heatsink and it must fit into my case.
Thanks.
Thanks.
