will a ultra x2 550w psu fit in a sg01-e fine?
Soymilk
i seem to remember that ultra's psu's are a little bigger like ocz's, right? would there be any issues with using a ultra x2 psu in the sg01-e? i saw it at fry's today for $60 AR, which looked like a pretty good deal, im currently debating whether or not i should go back to get it. of course, if it won't fit / will cause issues w/ the optical drive i probably wont.
MrE
The power supply is not the issue, the Opitcal Drive is. See my signature, but yes, it will fit just fine.
-E
Soymilk
thanks.
will a nec drive fit with it? i know lite-on's should, but i want to have more options :p
i'm building in about a week or two (when amd cuts prices), and haven't bought anything other than ram and a hard drive (which i just stuck in my current comp for the time being :p), so if a nec drive is too long i guess i can go with lite-on or something.
Steeeeve
nec are the longest....that might be pushing it...I doubt it. You have 8" and the NEC is around 7.46"...so you are pushing it but it might work.
