Will a RX 550 do 4k/120Hz/4:4:4 via DP?
Thinking of getting a RX 550 for a HTPC build, I have a display that is capable of doing 4k at 120hz, if I use the DisplayPort will it drive 4k at 120hz at full RGB chroma? Is the RX 500 series capable of running 4k/120hz/4:4:4 via the DisplayPort?
I don't plan on playing games or doing anything intensive on this card obviously.
You can do 4K120 but I think it will be at 4:2:2. Honestly, this makes no difference for movies, as they are already chroma sampled.
I've already ordered a RX 550 and will post the results when I receive it, I assume that using DP 1.4 on a budget card would signal full RGB at 4K 120hz.
