Will 750w PSU be enough for my new budget-mid build?
Taurine
Hi!
I am looking forward to upgrade my old PC, however I am not sure if this 750w PSU(Corsair CX750) will be enough?
Motherboard: Asrock Z97 Anniversary
CPU: Intel i7-4790K
Video card: Sapphire AMD Radeon R9 290
Memory: 16gb 1866mHz DDR3 Kingston Hyperx
HDD: 1x7200rpm 2TB + 500gb SSD
+ some Bluray player/writer.
Thanks!
Although the Corsair is semi-modular, I would avoid it. Not impressed with the one that I have, first lasted ~5 months. May or may not be indicative of the product, but it didn't work for me.
Second time around, I went with the EVGA 750 G2.
I have a Corsair CX430M @ my parents home that I built for them. It's an OK PSU for really light duty, but as Kidius mentions...I wouldn't use it as my main computer. That XFX 650 (see my sig) is more then you'll need & that's a fine PSU. I'm in fact using an older XFX 650 PSU that's been running great for over 5 years. It was also a Seasonic build.
