QwertyJuan
- Aug 17, 2000
I've run into this before and didn't know if there was a work-around....
Let's say you have a network called "home"... on that network you have a password "1234567890"..... you connect using your phone or laptop, and it remembers it. Great!
Now, I decide to CHANGE my wifi password to "iliketoeatbabies", and my phone won't connect. So I have to go in and "forget" the network and re-connect.
So... you do this at your place of work with 75 people all on wifi.... 75% aren't bright enough to do this, so they all run over to you to get them to do this for them (forget the network and reconnect)
See the problem??
Any ideas??
P.S. The last while I have got around this by actually RENAMING the wifi network to something else completely. Tell them to connect to the "NEW" network now called "home1" and type in the new password. It seems to stumble less of the technologically advanced among us, but still not an ideal solution IMO.
See the problem??
Any ideas??
