eighteen_psi
- Jan 28, 2002
I found a good deal on an ethernet bridge for 24dbi grid (802.11b) antenna (as opposed to the orinoco and PCI adapter solution)...this is a better solution for integration and ease of setup but how can I connect to multiple networks?
I assume there's no way to use netstumbler or similar utilities with an ethernet-bridged antenna? The seller says it is controllable via an http interface requring an SSID...though it does have an automatic config. setting.
Does anyone have any experience using such a configuration? I am looking to connect to 3 or 4 networks (at this point, my school's wifi and the networks of a few friends in the area).
Also, does anyone know of a place that actually sells PCI adapters for the oriinoco gold PC card?
