I need some ideas from you guys!
At work we have a vendor that came in a wrote an application. Basically the box has to hit a server on our LAN as well as an internet site to function. Our network uses an ISA proxy to get outside of our network. Modifying anything on the enterprise ISA for one little application is not going to happen. Their code allows you to define a proxy server and this works to hit the internet resource. Unfortunately that then blocks out our internal server. If you disable the proxy the reverse happens. Ok, so proxy exception! Yeah, no. They did not code that into support their application.
My thoughts were to put a computer in place running some sort of proxy application to handle the http requests and route them directly to the right host. Unfortunately proxy software is not my specialty. Is this possible? Thoughts?
