Unknown-One
- Mar 5, 2005
What doesn't make sense?
That there are multiple places on the AVS chart that contradict the Toms chart?I'm still waiting for you tell me what doesn't make sense about it.
That the AVS chart is missing whole chunks of spectrum?
That the AVS chat doesn't even show the crossover dip in the same place?
Take your pick...
Already fixed that (like I said, scale on the bottom-end was wrong, the chart has been corrected).No it doesn't.......Your chart makes the Klipsch look ridiculously flat.
Already fixed that. The scale was compressed when it shouldn't have been. It's now 1:1.If that's the case, then why does your chart show nearly a +/- 3db change from 10khz-20khz, yet Tom's show it dropping almost 12db?
It does now, go back and read.Nope, sorry.
Edit:
Also, for anyone wondering what the MB42 --> MB42X upgrade looks like:
And after having a listen (with this EQ applied to make them almost perfectly flat), they are FINALLY objectively better than the ProMedia's.
And yes, I realize you can apply this EQ to the MB42's and get a flat frequency response graph out of them... but they still don't sound anywhere near as good as the MB42X's. I didn't believe the reviews, but they were totally spot-on: this doesn't even seem like the same speaker anymore. They can finally play multiple instruments, movies, and games without sounding like distortion and mud
Unfortunately, I had to spend a fair bit more than the ProMedia's to get here. $60 for the speakers + $30 for the crossover upgrade + $64 for the amp + another $20 on various cables. Grand total after all the tax and shipping was over $200. Ended up having to spend twice as much as I did on the ProMedia's to finally get something that perked my ears up.
