why no 3600 cl-16-16-16 GSkill is compatible wity TRX40 ?
kirbyrj
Given the general improvement in memory compatibility with Zen 2 CPU's. I doubt you'd have a problem running B-die if you're inclined to pay the steep B-die tax.
prime2515102
My motherboard isn't compatible with any G.Skill memory at all according to their site (it's not listed at all - MSI Z270 KRAIT). There are plenty of G.Skill kits listed on MSI's site though.
kirbyrj
That doesn't mean anything. All that means is that they didn't test it, but it should work fine.
thesmokingman
Any idea why no 3600 CL16-16-16 memory is here compatible with Asus Zenith II ?
https://www.gskill.com/configurator?page=1&cls=1529635169&manufacturer=1524725352&chipset=1574737122&model=1574737652&adSearch2=Capacity§64GB (16GBx4),Tested_Speed§3600MHz,
I though the B-Die F4-3600C16Q-64GTZR should be there on their compatibility list.
But onlu hinx ones with CL16-19-19-19 are. Why is that?
QVL lists are kind of worthless. I didn't even bother to refer to any qvl list.
https://hardforum.com/threads/build...-raid-render-monster.1990145/#post-1044426406
N4CR
Look for others running it if you want to be paranoid but really zen2 isn't going to be fussy with normal ram configs.
