My first load of XP Home on a new system failed so I had to reformat and load it again. After the second load the BIOS asks me to chose between two operating systems at start up. What's going on and how do I fix it?
I slid in the XP disc, booted the XP setup and selected the full format option (took 2.5 hours) on the only drive I have hooked up to it at the moment. On the C drive I only have one windows directory and the entire load takes up 3.06 GB. If you chose the second OS option it gives an NTDRL error.
I edited the boot.ini file to only show one operating system. If there's another one on there how would I go about finding it so I can delete it and set up an OS properly?
Just for the record: Your Bios does not hold ANY operating system information at all. Ever. Unless you have a BiosRom with OS right on it (like Amiga or Atari ST etc.).
The Boot information is stored in the bootsector of your harddrive.
