wra18th
- Nov 11, 2009
I went USB 3 for all optical drive needs. I do use it but I keep them in the drawer.
Yup. I love my icydock.Heck. The only reason I want 5.25 bays is because you can convert to 4-8 2.5” drives in a bay.
Agreed. Only place you can fit the zip drive. Or the 8 track player.If your PC doesn't have any 5.25" bays then it's just substandard.
Yep, substandard that we are no longer putting in bays for outdated media.If your PC doesn't have any 5.25" bays then it's just substandard.
8x SAS SSD in 5.25" bay is not outdatedYep, substandard that we are no longer putting in bays for outdated media.
I should really revise my stance, I guess. CD's are worthless and stupid to keep. That is specifically my point with my first message, most notably because they were saying they wanted the drive space for burning CDs.8x SAS SSD in 5.25" bay is not outdated![]()
Oh agreed. But the BAY is useful!I should really revise my stance, I guess. CD's are worthless and stupid to keep. That is specifically my point with my first message, most notably because they were saying they wanted the drive space for burning CDs.
I wouldn't suspect much difference over NVMEs jammed right against the board and usually just above, or under, the GPU lolWouldn't you have problems with heat with the 2.5" SSD drives packed so tightly? Looks like there would be zero room between them, basically, along with probably not getting much airflow to cool, particularly the inner ones.
Zip drives go just fine in 3.5" bays.Agreed. Only place you can fit the zip drive. Or the 8 track player.
True, but at least they (generally) get at least some air flowing over them. Also you can install heat sinks on them and some of them even come with them. Most cases have the 2.5" SSD mounts right against the side or front of the case, where little air would reach. With one or two, I wouldn't imagine it being much of a problem. But with eight, jam-packed in a 5.25" bay, against each other.. I'm not so sure. It would be interesting to see if there would be any way to test the thermals in such a setup.I wouldn't suspect much difference over NVMEs jammed right against the board and usually just above, or under, the GPU lol
Most older laptops have the 2.5" position under the laptop with little or no airflow. With a single drive it's absolutely no problem. With a set of 8, it might be a bit hot, but in a sufficiently cooled PC and room it should be fine. With 24, you probably want forced air cooling on at least one side of the drives.True, but at least they (generally) get at least some air flowing over them. Also you can install heat sinks on them and some of them even come with them. Most cases have the 2.5" SSD mounts right against the side or front of the case, where little air would reach. With one or two, I wouldn't imagine it being much of a problem. But with eight, jam-packed in a 5.25" bay, against each other.. I'm not so sure. It would be interesting to see if there would be any way to test the thermals in such a setup.
You are substandard clinging to outdated tech. You need at 5.25 drive? Good for you.If your PC doesn't have any 5.25" bays then it's just substandard.
Literally nothing outdated about 5.25" bays. Cd drives, sure.You are substandard clinging to outdated tech. You need at 5.25 drive? Good for you.
I disagree with you on this. The main purpose of 5.25" bays was/is to hold 5.25" drives, which themselves are outdated. That said, they have been repurposed in many ways, so they aren't obsolete, but I would still argue they're somewhat outdated.Literally nothing outdated about 5.25" bays. Cd drives, sure.
Idk, I still wouldn't chalk that up to the 5.25" bay being outdated. It can do things that no other solution can. I think if general PC users had a wider knowledge of what 1 or 2 of them can enable, you'd see them around more.I disagree with you on this. The main purpose of 5.25" bays was/is to hold 5.25" drives, which themselves are outdated. That said, they have been repurposed in many ways, so they aren't obsolete, but I would still argue they're somewhat outdated.
Sure, there are case manufacturers that include them today, because the drives are not obsolete and are still of some value to some users. But most cases no longer have these bays because the majority of consumers no longer need them. As a general statement, the PC community has largely moved on from 5.25" drives and bays. Albeit not completely, which is why you do still see them available to an extent.
such as? res bays are gone, optical is next to dead, fan controllers maybe, but what else?!if general PC users had a wider knowledge of what 1 or 2 of them can enable
usb/media card readers, lcd displays, hot-swap bays, tool trays (for the really old school), buttons and knobs...such as? res bays are gone, optical is next to dead, fan controllers maybe, but what else?!
usb readers are usually 3.5, ok maybe hot-swap bays, lol ok...usb/media card readers, lcd displays, hot-swap bays, tool trays (for the really old school), buttons and knobs...
As mentioned before, most compact way of storing SATA ssds. Being able to fit 8 of them in a single bay is incredible. Better than having a couple of them bolted to random places in the PC. Some even open from the front for hotswapping.such as? res bays are gone, optical is next to dead, fan controllers maybe, but what else?!
ive watched all the shit that goes into them come and go.As mentioned before, most compact way of storing SATA ssds. Being able to fit 8 of them in a single bay is incredible. Better than having a couple of them bolted to random places in the PC. Some even open from the front for hotswapping.
Same with m.2 ssds.
Res bays aren't gone. Can still find them around. I'm using one of the nice koolance ones that has dual d5 pumps. All in the space of 2 bays. The aquaero 6xt is also really nice.
I feel like 5.25" bays get a lot of flack because people instantly dismiss them as "lol cd drives" without bothering to read any further.
Eh, that's their loss then. Doesn't change the fact that they're by far the most versatile bay in a PC and many people don't bother to even consider them outside of being a cd drive.ive watched all the shit that goes into them come and go.
so as stated, there are a couple specialized things that go in them, that 98% of people never use.
and as i stated on page one, two years ago, you can still get them IF you need them...
With 5 1/4" bays, I feel like I need a massive case to make building the machine not suck. I'm still using a big case, but the O11 Dynamic XL for example is way smaller than any case I've had in years and offered similar ease of building out the system as my larger cases did.The easiest thing is to get an external disc drive if you need it. This is especially helpful if you have a mATX/mITX build. Even today's typical ATX mid tower frees up so much space by leaving the internal 5.25" bay out.
I have older games ripped to ISO, or I download them as I need them.My last case I made sure to get a drive bay. I like having the option if I get an itch for an old game I have and want to replay.
I get that, but there's just something to owning a physical copy that I prefer.I have older games ripped to ISO, or I download them as I need them.
Pretty much. Those bays are just in the way for cooling, fan placement, wire routing.With 5 1/4" bays, I feel like I need a massive case to make building the machine not suck. I'm still using a big case, but the O11 Dynamic XL for example is way smaller than any case I've had in years and offered similar ease of building out the system as my larger cases did.
I own copies of all my games. It doesn't mean I want to wait an hour to install a game from a disc because of the slow speed. Personal preference, I guess.I get that, but there's just something to owning a physical copy that I prefer.
To each their own!I own copies of all my games. It doesn't mean I want to wait an hour to install a game from a disc because of the slow speed. Personal preference, I guess.
It's funny we are all talking about this, because I noticed that my PC at work, which isn't THAT old (i5-6500), has a spot for a floppy drive.To each their own!
It took me until 2014 or so to get rid of my floppy drive.
Just get a Linux distro version of the movie at the point. Will be better quality then DVDs too.My newest case is a Phanteks (PH-ES614PTG_BK) Enthoo Pro I specifically picked this for the 3x 5.25" bays!
I still use optical media I buy CDs and DVDs (as well as Blu-ray discs but not as many) at second hand (thrift stores) stores for cheap and I need the drives to rip the content for my media server.
you used to be able to get floppy drive that connected to the internal usb header, sorta like this aio unit:I doubt it actually has a place on the motherboard to plug in a floppy drive though. It is probably just a 3.5" external drive bay
