Erasmus354
- Mar 12, 2004
Why do you need air filters? After a couple of months my radiators seem to be doing a fine job of filtering out the dust all on their own
internal water cooling also stopped my cat from sitting on top of the case. though he still likes to de-fur himself into the intake fans in the front of the case. I don't use air filters either, I just clean everything out with the air cans and tissues every few months.
Cool. So thats your P2 system? lol
I doubt he's got such an elaborate cooling system for a Pentium II.
I know, im just playing. Read his "Main Rig" in his signature.
Because internal watercooling is beautiful....
A much better solution for this.... run a vacuum cleaner through your house on ocasion. I somehow doubt a couple of undervolted 120mm fans are going to clear a noticable amount of dust from the air. On the other hand I don't doubt that those filters will hinder airflow across my radiator which is why I have the fans in the 1st place. Dust filters do have their place, however they are not a universal must.
Mines on the outside...
It looks cooler on the outside, and as mentioned before there's less water in your case so less chance of leaks
Yes, I know. DualBrain saw my worklog and asked if I wanted to submit my pc to his website... and I accepted.
I am in the process of doing this with my antec 900 also. Just waiting for the triple rad. I think it look cool. Not as bad as some of the eyesore cases out there. As long as its all same color I think its good.
I currently have my double rad inside the case right behind the fans and my temps at idle will dip as low as 20. Only thing is I now have a GTX280 and want more cool air flowing till I get a water block for it. So I am moving the rad to the side.
I was just thinking....
And with a radbox ?
They look like bent PCI brackets.Just wondering King Ice...Where you get the brackets to raise the rads off the sides?
I was going to do a similar side by side as King so it wouldnt make case plus rads to wide and I would go in series from one rad to the next. Essentially making it a penta-rad. Or would it be quintuplete-rad???? Anywho I got the parts why the heck not. I will get pics once done.
The placement of that case (with wheels) up on that drawercabinet does looks really macho
Drawbacks with a system like that is several, unpracticality, added restriction because of long watertubings... I would really consider to replace those 90 degree connectors with 45 degrees too, even tho 90' bitspowers is less restrictive than ordinary 90'.
I would also at least have replaced the watertubing from the cooler unit to the pc-case with watertubes with bigger internal diameter.
But thats me - I prefer all my components in one case - in an emergency I could have mounted a rad on the outside - back - of the cabinet.
All those issues where tested and worked out before the build began
Flow rates still up over 1.5 GPM on the CPU loop with the dual D-5's, so BP 90's not an issue. Tubings 1/2" ID-3/4" OD. CPU temp at 50 average 100% load @ 23.5 C ambient running Boinc 24/7, so I'm pretty happy with the design and implementation.
Any drawbacks from extra tubing length is far out weighed by the cooling performance gains by not having the rads exhausting heat into the main case. Right now my case temps are at or below the fluid temps in the loops, so the design really does work if done right.
Just depends on the build and what your design goals are regarding external rad boxes and such. Based on my criteria, a multi case system was the only way to go.
andyc
Your system is one of the better looking ones compared to to a lot others I have seen with external LQS - thats for sure.
I went for a case with room for it all - and with two separate compartments as the Tagan A+ Black Pearl have heatdump isn't a issue.
Now in the rebuild of my mainsystem I decided to add a dedicated GFX loop - this radiator will be installed in the upper compartment since there is really no more room in the lower compartment. In the lower compartment I now have a Feser Monsta rad with 6x140 fans attached and the enormous Koolance LQ 1700Watt PSU ( + 25cm long ! ) , a 120mm rad for the psu and a whole three pumps.
To remove the heatdump from the dedicated GFX 2x120 rad - which will be installed on the inside of the right hand side door - I did install 2x140 mm fans on the inside of the left hand door - almost straight in line for the GFX rad.
In order to get the airstream from the gfx rad straight over to the 2x140 exhaust fans I did use beam air adapters.
It seems to be working very well - and I still maintain positive pressure in the upper compartment since I have three casefans too.
Even there are 16 fans in my system - it is not much noisy - all fans do run on very low speed.
You can see some pictures in the link in my sig.
I know its been nearly a month with no post in this thread but I just wanted to say that I am working on a P180 case mod where the radiator is on the outside just like Kings. I will post pics when I finish. Also going to attempt to put a window in the side panel too.
