Why does manufacturer put dust filter on top outflow fan, but not on rear outflow fan?
Discussion in 'Cases & Case Modding' started by Happy Hopping, Jul 26, 2019.
  1. Happy Hopping
    Happy Hopping [H]ardness Supreme
    6,578
    Jul 1, 2004
    pick NZXT Phantom for e.g., there is dust filter to cover the top OUT FLOW 2 x 200 mm fan, but needless to say, the rear 1 x 140 mm fan, there is no dust filter
    Now, we all put dust filter on in take fan, that's normal. So what is the reason these manufacturer put dust filter at the top out take fans, but not the rear out take fan?
  2. Van0
    Van0 n00b
    21
    Oct 22, 2017
    It's on top to prevent dust falling into the system should there not be a fan installed or for when the system is off. This isn't necessary for the rear fan as dust cannot naturally fall into the opening.
    GSDragoon and vegeta535 like this.
  3. jimbob200521
    jimbob200521 Gawd
    574
    Mar 23, 2013
    Some people use the top vents as intakes, therefore a filter would be a good idea. If used for exhaust, I'd remove it. But you never see a filter on the rear fan because I don't believe anyone would use it as an intake (I'm sure there is someone but they are the exception rather than the rule, so to speak).
  4. Happy Hopping
    6,578
    Jul 1, 2004
    thank you for the input
    I have some dust at the top of my phantom but I'm sure it's used as outtake fan
  5. Panzer_X
    Panzer_X n00b
    16
    Aug 14, 2019
    It could be for it the case has negative presser or something like that.
  6. Wang191
    Wang191 [H]ard|Gawd
    2,026
    Nov 30, 2000
    I put a filter on my top vent to keep junk from falling inside the case. You never know when a stray screw will fall off your desk and onto the case. I also had filters on the intake fans to filter the incoming air.
  7. Happy Hopping
    6,578
    Jul 1, 2004
    In the end, because this is a Jonsbo MOD 1 case, I have to put a filter at the rear as well as the top, because w/o it, there is a big hole at the fan, so after I put it together, I have no choice but to put filter in ALL of those spots, rear and top x 3.
