Why do PC Games take a few seconds (5 to 6 seconds or less) to exit?
ng4ever
I have a SSD and the games are installed on there.
My PC specs are:
i7 7700k
32 GB of ram
Geforce 1080 ti
500 GB SSD
4 TB SATA drive
Shutdown processes
releasing resources sensibly
saving ini files and other logs (can hold up shutdown processes if the SSD is busy)
retrieving swapped out OS data from the swap file
Do some benchies on your SSD to see if it needs some tlc.
It might be a crappy SSD.
Memory management. In both system RAM and GPU RAM, hard drive cache etc.
the AI's are spying on us, they are sending back data to the overlords
its true
some one told me
cant tell you who
^this. And for the medics + ironsmiths to fix the shit you broke!
Do you think all those resources the game allocates just release and cleanup after themselves? Semi-serious question.
