As you stated, the slider does nothing for any card except the Lightning and PE, but it doesn't hurt anything either for other cards, it just doesn't do anything. Its certainly not going lower voltage and make worse overclocks. Bottom line, the slider does NOTHING for a standard kepler card, only the Lighting and PE.
Whenever I adjust the voltage slider in MSI the voltages do drop. Have owned 5 different kepler cards and all of them behaved this way.
In afterburner, the voltage slider does nothing good. Overclocking via evga precision or nvidia inspector, you should move the voltage slider to max, it caps the voltage at 1.175 on load. Helps my reference cards maintain a little higher core speed compared to auto voltage.
The voltage is capped at 1.175 whether you move the slider or not. And Afterburner and Precision are just different front-ends, they both have the same functionality.
You misunderstood me, or i explained it wrong. Either way, precision or inspector doesnt drop the voltage from 1.175 at any point. Afterburner cant hold on to that 1.175v, after 60/70c it drops voltage to 1.162 and so on. Precision does not.
edit: example. my cards are both running ~1250/1750. If i use afterburner, after 70c(or60, cant remember) the voltage drops from 1.175 to 1.162 and crashes drivers due to that. Precision voltage slider at 1.175 does not drop voltage when exceeding 70c and my cards stay stable.
