Why Cisco switch over 3com switch
Discussion in 'Networking & Security' started by Asgorath, Mar 28, 2007.
  1. Asgorath
    Asgorath [H]ard|Gawd
    1,253
    Jul 12, 2004
  2. MorfiusX
    MorfiusX 2[H]4U
    3,007
    Feb 13, 2004
    I would go with the Cisco because I have seen more random lock up issues on 3com gear than I can count.
  3. da sponge
    da sponge [H]ard|Gawd
    1,133
    Aug 23, 2001
    Don't forget HP Procuves in your evaluation.
  4. Asgorath
    1,253
    Jul 12, 2004
    You've seen the 3com switches lockup? Unmanaged 3com switches locking up?
  5. Boscoh
    Boscoh [H]ard|Gawd
    1,161
    Nov 25, 2003
    The 3560-24TS is not a POE switch, the -24PS is the one you want if you want POE.
    Make sure you understand the QoS limitations of the 3com switch. From what I understand, their QoS support is VERY basic (perhaps someone here more familiar with it can comment on exactly what it can do). I know the 3560 supports a ton of QoS options (I'm working with QoS on one as we speak), including remarking packets, shaped/shared round-robin with priority queueing, extension of trust boundaries to cisco IP phones (if you use them), and adjusting mappings of different markings.
    Also, the routing support on it (3com) is limited to RIP and statics. Could be an issue if you're running a network using a different routing protocol.
  6. MorfiusX
    MorfiusX 2[H]4U
    3,007
    Feb 13, 2004
    I have seen both managed and unmanaged lock up.
  7. unix_foo
    unix_foo [H]ard|Gawd
    1,326
    Jun 21, 2002
    Cisco, because everytime you add another vendors networking gear to a Cisco rack John Chambers kills a kitten.
  8. versello
    versello 2[H]4U
    2,062
    Nov 19, 2003
    I'd prefer Cisco because it would be easier to support in the long run... at least in my opinion...
  9. niccoli
    niccoli Limp Gawd
    432
    Feb 13, 2002
    I agree with unix_foo :)
    Actually, I would go with the Cisco, I've stopped counting the number of customers where we've gone in seeing weird issues, start pulling core 3com switches and put cisco or hp switches in their place and the issues magically go away, both managed and unmanaged 3com switches. They also don't have as many features from what I have found.
    That being said, I have a friend in the IT field who is in the National Guard and he swears by 3com switches...for what that's worth.
  10. Asgorath
    1,253
    Jul 12, 2004
    Any particularly good place to buy cisco from?
  11. mobiux
    mobiux 2[H]4U
    2,626
    Jul 24, 2000
    Yeah, 3com's have an issue with multicasts too.
    I can't multicast connected to certain closet switches, or they slow down to nothing.
  12. niccoli
    niccoli Limp Gawd
    432
    Feb 13, 2002
    Used - ebay isn't bad, I use a vendor called optimumdata, have bought quite a bit of used cisco equipment from them and have had very good luck, they are very easy to work with and they have overnighted me parts on numerous occasions to get me out of a bind.
    New - I usually get pricing through at least 3 different vendors that I have used in the past, all are good but, as I have found with all cisco equipment, the markup is a joke. I normally get 3 quotes and then play them off each other, usually at least one of them will give me a better deal and that's who I use
  13. JayAre
    JayAre Limp Gawd
    245
    Jan 20, 2007
    HAHAHAHA.....that is awesome!!
    Well I agree with your generalized statement, it wouldn't make it easier if the IT person putting them in, doesn't know Cisco IOS.
  14. Eickst
    Eickst [H]ard|Gawd
    1,786
    Aug 24, 2005
    Some of the Cisco switches have Web GUIs to set them up. You don't necessarily have to know IOS.
  15. Nate7311
    Nate7311 2[H]4U
    3,312
    Jan 11, 2001
    HP Procurve 2626-PWR (J8164A). No crazy 3Com issues, and an alternative to the Cisco Machine
    Do a froogle search, they turn up for $1200-$1500.
    And Lifetime, " Hey guys, my switch is broke. Ship me a replacement Next-Day!" warranty FTW!
  16. JayAre
    JayAre Limp Gawd
    245
    Jan 20, 2007
    While this is true. Not all commands that are available through the web GUI, as they are through the CLI.
  17. Eickst
    Eickst [H]ard|Gawd
    1,786
    Aug 24, 2005
    Oh no, definitely not all commands are there. But you can do basic setup, VLANs, QoS, etc. in a limited fashion. More than enough for a small company who's IT guy has no clue what he's doing anyway.
  18. PopeKevinI
    PopeKevinI 2[H]4U
    2,880
    Mar 25, 2002
    We have manged 3Com throughout our school district, and have had just one problem: on one of our three 7750s, a single 48-port blade stopped responding and took out a third of a campus. Reseated it, problem solved. We think the blade is bad, but don't have the time now to take down the network to test it.
  19. tdg
    tdg 2[H]4U
    3,816
    Jan 27, 2003
    Look into HP's Procurves, as reliable as Cisco, great support and lifetime warranty, all for quite a bit less money.
  20. Haven
    Haven I Only Post Important Stuff
    6,064
    Oct 11, 2002
    I have to agree with the people that have suggested the HP Procurve.
    We are swapping out our older Cisco switches with an HP Procurve model. We looked at a Cisco solution and an HP solution, and the HP was more cost effective. Same features for the most part, the Cisco didn't have POE and the HP did, but the HP was 1/2 the price of the Cisco. Plus we would have had to spend an additional $4K per year on Smartnet for the Ciscos.
  21. BartY
    BartY Limp Gawd
    226
    Mar 1, 2007
    Umm...kinda. The web interface is good for basic stuff and monitoring, but most advanced tasks are still easier to do via IOS. Then there are some commands that aren't available anywhere BUT the IOS.
  22. niccoli
    niccoli Limp Gawd
    432
    Feb 13, 2002
    One other recommendation, Extreme Networks, I use their switches quite a bit and overall compared to a Cisco switch side by side I've almost always found the extreme to be much easier to work with and quite a bit faster. I have one of their Black Diamond 6808's at the core of my fiber to the prem network and it's very good at what it does, route packets, BGP routing, 150 VLAN's on it and the thing just sits there and goes, switching packets all day without a problem.
  23. unix_foo
    1,326
    Jun 21, 2002
    My manager ask my team to find ways to cut some budget. The stupid Avaya whore in my team mentioned that we could stop rolling out Catalyst 3750 at the access layer for HP ProCurve or Extreme. HP ProCurve is ok, pretty good deal with their lifetime warranty. Although they currently do not have a 1U unit that can push 15w POE on all 48-port. A requirement for my company's line of business. We demoed Extreme and we were fairly pleased. No proprietary technology and pretty robust gear. The chasis based gear that we demoed switches fast...i mean fast. I was getting ready for Extreme but a couple Cisco !!!!!!s opposed the idea. To cut the story short , something lead to another .... stability and redundancy was brought up and now we are getting ready to roll out 6509 with dual sup32/dual ps at the access layer. It turns out, by dropping smartnet on every access layer device that we own and just carrying spares for emergency we were able to save the $500k my manager was trying to cut.
  24. brom42
    brom42 2[H]4U
    3,995
    Mar 1, 2004
    ProCurve all the way. We buy broken units off of eBay on the cheap and get them replaced using their lifetime warranty.
    There is nothing like getting a broken 2650-pwr for $300 off of eBay and exchanging for a new one from HP through their warranty. :cool:
