Bullitt said:Aside from cabling, I dont see where a SATA optical would be "better" than an IDE drive. By Better, I'm speaking of performance issues. Any modern burner doesnt even come to the UDMA-33 limit, much less SATA150/SATA300 speeds. If I wanted the "Hot swappability" I'd just go for an external burner via 1394 or USB. I really don't think the market demands a SATA burner yet. Besides, Plextor already has their line of external drives so I dont see why they would be too keen on introducing another hotswappable-capable drive to their lineup.
J-Mag said:I agree, wtf is the point of a SATA optical drive? I would much rather use all my SATA ports for Hard Drives.
Poncho said:The reason there is a need for SATA drives is that the next generation of Intel platforms will have NO ide on the ICH, so unless there is an external controller that is added by board manufactures then you'll need to get SATA optical drives. I would imagine that AMD would make this switch eventually as well.... just not sure when.
Mysogonist said:Personally I think it's just time that we move away from all legacy devices. I have a feeling that legacy devices (Serial Ports, Parallel, IDE, FDD) cause a number of headaches for both chipset makers and board manufacturers. I always disable all legacy devices on my boxes except for one IDE channel used for optical devices. The sooner we make that transition...the better IMO.
I can do that with my IDE cables... well if I get flat ones instead of these ugly round ones.Karma said:My main reasons for considering SATA opticals is specifically for cable management and a cleaner look. Being able to run the SATA cable under the motheroard is very appealing.
that's exactly how I feel. The rounded IDE cables that come with a motherboard I always just cut off the plastic so it is flat again..santaliqueur said:i think flat ide cables are easier to work with than round ones, but i'd rather have sata cables for everything.
IanG said:Weren't the old Plextor drives just the regular ata version with an sata bridge literally bolted onto the back? I image that once people realised they could do this themselves for significantly less than the premium they were paying plextor, they decided to drop the models.
IDE is not terrible to hide if they are folded properly, but most of the time the cables that come with motherboards are too short. I usually just end up making a couple folds to lead the cable up to the top of the case, and then sort of twist it where it connects to the optical drive.Impulse said:As far as cabling issues, I agree with Borgschulze. If you use flat IDE cables and learn to fold them well they're really no harder to hide than SATA ones and even easier sometimes depending on the case...
