Server 2008 R2 install
WHS installed in Hyper-V
All disks (except OS) added to the WHS as passthrough disks
ISSUE #1
Added the Disk Management add-in to WHS
- Hard drive activity shows up fine
- BUT, hard drive temp shows up as N/A
Any ideas why? Or another good way/place to access the temp? I don't really need constant real-time monitoring... just want to get an idea of where temps are at in a new case setup (since I have a feeling they are a little high due to a fan swap in a Norco 4220). If it's something I need to monitor from within 2k8 rather than WHS that's fine... just need to know
ISSUE #2
This one is a bigger issue and it involves my (in)ability to hot swap drives. If I try to add a drive, it will usually show up in Disk Management... but I can't seem to really do anything with it or get it to show up in WHS. And while I can usually add and put one drive offline, if I start trying to add more or really do anything, Disk Management just crashes and I the only fix seems to be a full restart of 2008...
Now, if I shutdown Hyper-V / WHS, and THEN start adding drives.... everything works perfectly. So basically I *can* hot swap... I just can't do it with a VM open.
Is this normal behavior? It's not the absolute end of the world but certainly restricts the utility of being able to hotswap since I have to shutdown WHS, add the drive, then restart WHS.
It is also going to make populating my wireframe drive layout in WHS an absolute BITCH if I can't pull/re-add drives with WHS running to figure out which drive bay is which drive!
ISSUE #1
ISSUE #2
