Who removes AG coatings?
Discussion in 'Displays' started by icor1031, Aug 21, 2018.
  1. icor1031
    icor1031 [H]ard|Gawd
    1,268
    May 29, 2010
    I remember from years ago that someone on this forum removed AG coatings, for a fee. Where can I find more info about that?
  2. Armenius
    Armenius I Drive Myself to the [H]ospital
    18,617
    Jan 28, 2014
    No one, anymore. Apparently manufacturers are using a different type of adhesion process or something. I vaguely recall the [H] member who used to do it tried it on a PG278Q and it ended in disaster with the polarizer chipping off.
  3. xp3nd4bl3
    xp3nd4bl3 2[H]4U
    2,259
    Sep 25, 2004
    I hear you, man. I despise AG coatings. Semi-gloss is just so much better to me. I wish there was more choice.
  4. icor1031
    1,268
    May 29, 2010
    I think I've asked this before, but how does semi-gloss compare to full gloss, regarding text sharpness?
  5. xp3nd4bl3
    xp3nd4bl3 2[H]4U
    2,259
    Sep 25, 2004
    I think there are a lot of varations on what "semi gloss" means and a lot of time it still includes coatings with varying degrees of graininess. I was referring to a monitor with the coating removed or no coating at all. I've only had two of them but I found them to be nearly as clear as glossy with deep blacks but much less glare.
    Armenius likes this.
