Who is looking to upgrade to Zen2
Discussion in 'AMD Processors' started by Kato1144, May 27, 2019.
  1. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    11,931
    Jun 13, 2003
    Wouldn't that be more of a side-grade, at very best?
  2. notarat
    notarat [H]ard|Gawd
    1,748
    Mar 28, 2010
    [ strike=]What's your point[/s]
    nvm. not important.
    meh...no strikethrough font (or I dunno how to do it)
  3. Legendary Gamer
    Legendary Gamer Gawd
    652
    Jan 14, 2012
    As far as I know the A320 is out of the realm of support entirely, the only place that sucks for me is that midget ASROCK system I just picked up the a300 "AMD NUC" I now dropped a 2200 into. Some B350 & X350 boards will be supported on an individual Manufacturer basis. That has been said since Ryzen 1 was first announced, tho. This is nothing new.
  4. tangoseal
    tangoseal [H]ardness Supreme
    7,684
    Dec 18, 2010
    Yeah there isn't the power delivery on a320 for much to be honest.
    I have an a320 in my son's PC and I'm gonna probably offer it in a buy something of mine and you get this board free solution
  5. mvmiller12
    mvmiller12 Gawd
    875
    Aug 7, 2011
    I've heard that Asus (from a Gamer's Nexus video, I think) is expecting to support the entire announced line up of Ryzen 3000's on all of their B350, X370, B450 and X470 boards. I can attest that they have been rolling the new AGESA out on all of my Asus AM4 boards...
    On topic, yes. I DO plan to get a new x570 board and a Ryzen 3000. I'm building my brother-in-law a new system as a gift because he is still on a Phenom II x4 840 system with 4G of RAM. My Crosshair VI and 2700X will trickle down the line, freeing up the Prime B350-Plus board and Ryzen 7 1700 chip for him.
    My plan is to build him a soft-tube liquid cooled system based around those parts, using my now-spare Koolance Exos 2 750. I picked up that $129 Geforce GTX 1060 6G (EVGA SSC GAMING ACX 3.0) from Kyle for this system, and I already have a small case that was left over from my cousin's old build. I have a spare Koolance CPU-380 block that will go on it, and plan to install an additional 240mm Koolance aluminum radiator I have sitting around into the case (I migrated to copper rads last year). I will be using my now-replaced older style Koolance QDCs with the Exos to make transport easier. I also already have a 450W power supply, but I may need to replace that. I will probably just run the CPU at stock to avoid potential problems he isn't equipped to deal with since he lives across the country from me - it'll still be a massive upgrade over what he has, even if I'm not pushing it to 3.8GHz.
    Still need to get the aforementioned x570 and Ryzen 3000-series CPU (probably 3700x), a water block for that 1060, some RAM, an SSD, and a large HDD for bulk storage...
    Mode13, Pieter3dnow and muxr like this.
  6. sc5mu93
    sc5mu93 [H]Lite
    126
    Jul 11, 2018
    65w 3700x is really appealing. now they just need to add igpu for my htpc...
    N4CR likes this.
  7. Mode13
    Mode13 Gawd
    661
    Jun 11, 2018
    I keep having the thought to myself that the 3700x is the binned one, because it's able to maintain those clocks at a much lower voltage than the 3800x.
    Will the 3800x be able to undervolt and be stable at the same clocks? Higher clocks?
    Will the 3700x have the same or possibly even better OC potential than the 3800x?
    :::head spinning in circles with excitement:::
    Kato1144 likes this.
  8. IdiotInCharge
    11,931
    Jun 13, 2003
    I'd get excited if they dropped some form of GPU + 4GB or 8GB of HBM into the spot where that second CPU die is going. Somewhere between RX560 and RX570 plus eight cores?
    That'd handle anything at decent settings at 1080p and perhaps most at 1440p60 with conservative settings.
    kirbyrj, Kato1144 and Legendary Gamer like this.
  9. Silentbob343
    Silentbob343 [H]ard|Gawd
    1,754
    Aug 2, 2004
    looking to upgrade my server. Do we know RAM capacity for consumer level boards?
  10. Vader1975
    Vader1975 Gawd
    820
    May 11, 2016
    I'm going to wait for the 16Core release the 8 core and 4 core chiplets isn't what I want. I want the 8 and 8 core chiplets. It will happen. Note I am running 64GB of DDR4 on a 2700X(4300mhz) ram at 3000mhz. I have not heard if the new CPU can support more or not?
  11. Pieter3dnow
    Pieter3dnow [H]ardness Supreme
    6,789
    Jul 29, 2009
    It does ;) checkout the [H] AMD motherboard section the video is where Buildzoid explains all of the ins and outs for motherboards with the Ryzen 3000 series including compatibility and memory frequency.
  12. Legendary Gamer
    652
    Jan 14, 2012
    The a300 just came out... So, I would have kind of figured that the damn thing might be a bit more future proof for A-Series CPUs. Who knows, maybe it will be... I want to find out because, my only hope may be whatever replaces the 2500 (3500?) as a Gen 2 update to their APU/CPU combo.
    I wouldn't imagine that the lower end chips would even require more than what the A320 can deliver in terms of power. I just think this is more of board vendor / AMD choice to cut out the low end boards and focus on the Mid to High end. AMD prolly dropped support of the low end chipsets because it makes more sense to slim the product stack on the MB side since the new stuff is significantly more expensive to support PCI-E 4.0 and on the Board Manufacturers end I would not expect to see many 300 Series boards supporting the 3000 series, because they want to drop support for older lineups not fight through the issues of figuring out how to deliver adequate power to the CPU on them. Gigabyte, of all vendors is supposedly enabling PCI-E 4.0 support on their older boards. So, at least one MB vendor out there is supporting the older chipsets.
    After the announcements of the new AMD lineup, I don't suspect you will have too much trouble getting someone to take that A320 off your hands. It's full capable of running Gen 1 & 2 Parts which will be selling at a healthy discount. Let me know what you do, I would be happy to throw some bones your way for the board. I was looking for another one to toss a GE200 into coming up here as a bedroom pc for music and web surfing.
  13. crazycuz20
    crazycuz20 [H]Lite
    86
    Oct 3, 2017
    I'll upgrade one of my 2 1700X's. Love the fact that Zen 2 is backwards compatible with X370, suck it intel with your unnecessary forced mobo upgrades so your investors can get richer off our hard earned $$'s.
    - Also need to upgrade my now deceased freenas i5-2500k. Will probably wait for the Ryzen 5 3400G
    Kato1144 and GHRTW like this.
  14. GHRTW
    GHRTW n00b
    38
    Aug 29, 2018
    DDR5 for desktop not until 2021 imho. Zen3 will be either DDR4 only or hybrid. My 5 cents.
  15. Manny Calavera
    Manny Calavera 2[H]4U
    3,617
    Jun 10, 2004
    X570 175 - 240 USD Mobo.
    2x16Gb DDR4 3000-3200
    Ryzen 3700X
    eVGA RTX 2080 XC Ultra.
    Intel 660p 2Tb nvme
    Is my current planned build for August.
    AgentM17X likes this.
  16. AgentM17X
    AgentM17X n00b
    11
    May 7, 2018
    hope no issues on first release of their products..
  17. somebrains
    somebrains Gawd
    769
    Nov 10, 2013
    It'd be cool to see how 3900x ran on your CH6 vs your next motherboard.
  18. pyr02k1
    pyr02k1 Limp Gawd
    415
    Nov 29, 2010
    Feel like I'll be on the same boat but replacing the 2080 with an AMD card and a bit delayed timeline wise. It's going to replace a Xeon 1270 and a 970 that were both second hand from a friend, so anything in the new line of cpus will be a nice upgrade. This system will probably make it's way to my nephews in it's entirety if I'm feeling cheap, or they're getting a R5 3600, whatever comes in just below it, or a used R7 2xxx if I find a good deal. Depends how the budget works out in the end.
    Next up is hoping to see the new TR stuff comes up and either get that or a used 2950x or 2920x to replace my dual 2650 server setup, though even a 3600x or 3700x might be a good bet there.
    Manny Calavera and Kato1144 like this.
  19. Gideon
    Gideon 2[H]4U
    2,317
    Apr 13, 2006
    I will likely keep my CH6 when I upgrade. However I am leaning more to the 3800X or 3700X. Alot will depend on reviews tho there is a small chance I will get the 3900X.
  20. Thatguybil
    Thatguybil [H]Lite
    96
    Jan 21, 2017
    Count me in that group. It will be interesting to see how windows handles assigning threads across chiplets.
    My chief concern is always single thread performance. The apps I care about are multithreaded to various degrees but are ultimately limited by the main thread on CPU zero. This is where I get worried about thread synchronization latency issues between different chiplets.
    Manny Calavera likes this.
  21. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
    For me, it is all about the SFF choices, so ITX & DTX...
    There is the absolute beast of a motherboard from ASUS, the ROG Crosshair VIII Impact DTX board...
    Then there is the ASRock ITX board with Thunderbolt 3...
    One of those two boards
    Ryzen 9 3900X 12C/24T CPU
    64 GB DDR4 (3200C14) RAM
    2TB M.2 PCIe 4.0 x4 NVMe SSD
    Navi PCIe 4.0 x16 GPU
    Corsair 750W SFX PSU
    NCASE M1 chassis
    Full PCIe 4.0 system, baby...!
    JMccovery and Kato1144 like this.
  22. funkydmunky
    funkydmunky 2[H]4U
    2,395
    Aug 28, 2008
    I agree. So it makes me think that there will be a reason. 70% higher TDP for 100MHz? Does not seem logical at all.
    I would guess that it will be the chip with some OC headroom. More cores will take that advantage away. It will be the one to get to or close to 5GHz. I am guessing this is the only highly binned sku. The peak of all the single chiplet CPU's will be 3800x's.
    Just a guess. We will find out soon enough.
  23. Pieter3dnow
    6,789
    Jul 29, 2009
    You can have certain aspects of binning, there are prolly more dies that will work on higher voltage given a certain frequency range and that part is suited for the higher TDP it does not have to work better for overclocking.
    We will have to see how good the 7nm process is for overclocking (65W vs 105W).
  24. funkydmunky
    funkydmunky 2[H]4U
    2,395
    Aug 28, 2008
    Ya okay. I am not seeing you offer a better reason for that much power increase for 100MHz?
    So in your opinion why 70%+ more power for a 100MHz turbo? What's you think is happening?
  25. Pieter3dnow
    6,789
    Jul 29, 2009
    It depends on how far ahead you can get on that process if it was obvious then AMD would have sold them at overclocked rating.
  26. tangoseal
    7,684
    Dec 18, 2010
    The chiplets are going to be transparent to windows.
    Threadripper already runs chiplets i.e. 2 separate dies or more. Works fine.
  27. britjh22
    britjh22 Limp Gawd
    384
    Oct 15, 2014
    If reviews on the 12 core look good, it will very likely replace my 5820k. Will be interesting to see how it does heat wise with a much smaller heatspreader than threadripper.
  28. IdiotInCharge
    11,931
    Jun 13, 2003
    Well, there are some issues with the chiplets that don't have memory connected on the 24- and 32-core Threadripper SKUs, but since no cores on Ryzen 3000 have direct access to the memory controller- and the access they all have is uniform- we shouldn't be seeing too many issues with the memory controller being 'non-uniform' (NUMA).
    We still do need to see latency tests for the platform and for inter-CCX and inter-die communication with relevant benchmarks.
  29. IdiotInCharge
    11,931
    Jun 13, 2003
    I'm wondering if we should look at this not as power draw directly. Aside from AMD's traditionally wacky TPD numbers, the extra TDP rating may be to allow for higher sustained boost clocks.
    What we don't know is if the lower part will be TDP limited, or if this SKU separation is mostly for OEMs. It may be that given the same enthusiast-grade power delivery and cooling, the parts could produce very similar results.
  30. Gideon
    Gideon 2[H]4U
    2,317
    Apr 13, 2006
    AMD stays alot closer to stated TDP then Intel anymore at one time that was not true but it is now. The 9900K is one of the biggest offenders of going way past the stated TDP, as a 95 watt chip should not be drawing 165 watts or so.
  31. Rizen
    Rizen [H]ardForum Junkie
    9,224
    Jul 16, 2000
    If the 3900X hits the mark that AMD has suggested it will, I will be onboard day 1 with a X570 system and the highest end Ryzen 2 chip they sell. Been waiting a long time for a new upgrade and I think AMD's platform is a lot more compelling right now, even if Intel has a small IPC advantage.
  32. SilverSliver
    SilverSliver Beat It To Deformation
    11,167
    Feb 23, 2004
    I have a 6700k, 3900x and X570 will likely get me to upgrade and I will use my current set-up for the family computer.
  33. Westwood Arrakis
    Westwood Arrakis [H]ard|Gawd
    1,126
    Nov 17, 2012
    This is the route I intend on taking in a few months.
    Kato1144 and arr4ws like this.
  34. crazycuz20
    crazycuz20 [H]Lite
    86
    Oct 3, 2017
    Buildzoid did a video on what he thinks should be compatible with 12 and 16 core Ryzen 2 based on the VRM's and the CHVI's look promising.
  35. IdiotInCharge
    11,931
    Jun 13, 2003
    Don't just use the halo part to make your point, if you're saying 'AMD' and 'Intel'.
  36. Gideon
    Gideon 2[H]4U
    2,317
    Apr 13, 2006
    Yeah I picked up the beta bios already for 3rd gen stuff and I believe the VRM is stout enough for the full lineup but you never know if it will allow full support of the cpu. ASUS has always been pretty good at support on their boards so I am hopeful.
  37. Gideon
    Gideon 2[H]4U
    2,317
    Apr 13, 2006
    Fine the 8700K is 95 watts as well and it hits 145 watts or so which is way beyond TDP. It's simple to compete Intel has factory overclocked their chips in gross violation of their TDP, AMD did the same thing with Bulldozer to try to keep up. It's one thing to go a bit past the TDP but Intel right now is shattering their TDP ratings. Which is obvious when you see a 7700K is 91 watts TDP and runs at 95 watts TDP on average and the 7700K was a halo chip at one time.
    Manny Calavera and N4CR like this.
  38. TheSlySyl
    TheSlySyl Limp Gawd
    161
    May 30, 2018
    Hoping for an upgrade, I have a 1700 that I want to pass onto my fiance and go for hopefully the 12 core. I'll likely need a new motherboard as well, as I need more SATA ports and M.2 slots so I've been wanting one for a while. I already have the case, memory, etc. that I'm gonna transfer over so if I spend about $750(?) between motherboard and CPU it'll still be a damn nice upgrade, I can hold off on a videocard upgrade for a little longer. Probably gonna get one (or two) of those fancy new PCI-E 4 NVME drives as well.
    Upside is that a new motherboard/CPU should be able to actually utilize all my memory at its correct timing, so I should be able to get it up to its rated 3200mts instead of its current barely stable 2800mts. Combined with higher frequency, more cores, and 20%(ish?) better IPC it should hold me over.
    I'm in a far better place financially now than I was when Ryzen launched, and with both of our systems being AM4 systems now I can easily pass off my current stuff to my fiance. Which is great, we both game but she doesn't care about all the fancy graphics or framerates as much as I do. 1080p60 should be enough for her for quite a long time. I already upgraded her to 32GB of ram, which even with her 200-300 tabs open at once finally seems like enough.
  39. jbc029
    jbc029 Limp Gawd
    475
    Mar 26, 2013
    That was kind of the situation for the 2700 vs 2700x. The boost clock algorithms reacted very differently to each processor, even though both were pretty regularly able to hit 4.1-4.2 all core OC. The 2700 natural behavior constrained it a lot more to keep it much lower on power draw, but you could force it to draw as much as a 2700x. I think that's what the TDP diff is here. The behavior in how aggressively it automatically pursues that auto-oc.
  40. IdiotInCharge
    11,931
    Jun 13, 2003
    ...if you let it exceed the TDP in the BIOS, which you're going to do with the AMD parts too.
