Yes, I'm having the same problem.bigmac said:Besides bleeding, anyone have problems getting it perfectly straight? Mine keeps wobbling ever so slightly. I guess the connector between the screen and the stand is not strong enough to support this heavy mofo.
Puterguru said:Also for people with their taskbar set to "Autohide", is everyone else getting a single visible line of the taskbar at the bottom of their screen? This just started when I started using this monitor, or the DVI connection. It's driving me nuts.
No It has not been there on any CRT I have used for the last seven years I have been using computers. It only shows up on LCD/DVI connections. I found a program to get rid of it.saltiness said:That's part of Windows. Everyone's does it, you might not have noticed it before if your old screen wasn't adjusted properly.
Nope no other program, seriously. It would have driven me nuts if I had seen it before. I noticed it immediately when going from my CRT to my Dell 2005. Nice 20 inch screen, beautiful wallpaper and an irritating little blue taskbar line at the bottom of my screen.saltiness said:Are you sure you didn't have that program before or something? I've always had the 2 pixel bar there, all the way back to Windows 98.
Wow that really is terrible. Worse than the one I just exchanged. Here is my new one that does have some in the bottom left corner. Would you guys keep this one or excahnge it? I think I can live with this. It's not perfect like I mentioned in my previous post but it's pretty good.hkky said:Here is a picture of my monitor
What do you guys think, should I keep this or is this as good as it's going to get?Puterguru said:Wow that really is terrible. Worse than the one I just exchanged. Here is my new one that does have some in the bottom left corner. Would you guys keep this one or excahnge it? I think I can live with this. It's not perfect like I mentioned in my previous post but it's pretty good.
Puterguru said:What do you guys think, should I keep this or is this as good as it's going to get?
