ashmelev75
- Nov 29, 2007
Why? What is the reason to purchase a motherboard at twice the cost of the CPU?
Did the world go insane in the last 5 years?
Possible insanity. Honestly, depends upon how nuts people are about Zen 2. I would love to pick one up but funds are tight and I might get fired soon... lol. Paying over 299 bucks for a fully loaded Mobo is insane. Typically, I consider paying 200 bucks insane given my typical use scenario (1 M.2 SSD, 1 SSD Swap (SATA), 16-32 GB of RAM and a ballsy Video card (I can use damn near any Mobo with those requirements).Why? What is the reason to purchase a motherboard at twice the cost of the CPU?
In more general terms, there are CPUs that cost way more than $700, and specific to Ryzen 3, there are CPUs that will supposedly cost at least $500 or more that are coming.Why? What is the reason to purchase a motherboard at twice the cost of the CPU?
I have bought some pretty expensive motherboard but they all have multiple sockets.
So have I, using a budget allocated to replace or increase datacenter gear.
Thinking about spending that much on a personally owned build will be difficult bc I'd have to justify it on some side work.
Even then, there's other places I'd put $300-400 saved on a "mid tier" mobo.
Maybe I'd justify a pcie 4.0 drive.
Im with you on this. I used to recomemend higher end boards when they were around 450 - 600 at the MOST.Why? What is the reason to purchase a motherboard at twice the cost of the CPU?
I've bought from the whole range of motherboards, from cheap (but not crap) to expensive (still less than $300), ran overclocked on every one, and never had an issue or a failure and some of the systems went on for 10+ years before being replaced for being obsolete.Dont think i would go 700 but im one of those who only purchase the higher end boards because i keep mine a long time and only upgrade when i can EASILY afford it
With current Win 10 updates breaking soundcards every year, and mobo manufacturers only providing 2 years of support, I would just go for a discrete soundcard.Creative still fixed X-Fi functionality for 1903 build on the decade old Titanium HD.I pay 210 or so for a microatx 2 nvme, x570, 8 sata, 1x 16x, 1x m2 wifi key, 1x 4x slot and a open 1x slot I believe.
+ more usb bandwidth.
That is a bit steep but "Ok"
Add 10gbit, 100 $.
Add 1-2 nvme more 50$ more.
Add premium sound 10-20$ more.
beefier vrm - 10$
400$ is the most I can think anyone would want to spend for a nichè in nichè market
True, but at least that GPU lets you game faster. Not sure what the MBO gives you to justify the price.In this day of $1200+ video cards, a $700 motherboard isn't really something to talk about.
its money well spent...and we both know that! IMO its the one thing in our box that we cant just swap out...at least convenientlyI don't think I'd spend $700 on a motherboard, but it turns out I will spend $400 on one. Don't get me wrong, this Crosshair VIII Hero is great, but come on...$379+tax? I'd feel better about myself if it was closer to $300.
If I were smarter I would have just hung onto my CH7 but I sold it a few months back.
Everything I've read that compares X570 to X470 and B450 mobos says they give you about 1-2% increase in performance for about a 100% increase in price!!! You better believe I'll be putting my (used in 3 years) R9 3900 on my X470 Taichi!!!!!
