Just picked up a z77 sabertooth (along with a $199 2600K at microcenter). couldn't resist.
Wish I would have noticed that this MB doesn't have firewire...I need firewire. Damn!
PCI-E card add-on for it?
Unless there's a Q77-motherboard coming with at least one 16x PCIe and one 8x PCIe I'm going for the MSI GD65 mobo mainly because of MSIs choice of hardware controllers. Gigabyte seems to have grown fond of Atheros/Qualcomm but their LAN-adapters have poor driver support and I'm not really convinced that they also work reliable in Linux/BSD. Both Asus and Gigabyte seem to switched from Realtek audio to VIA which is just horrible from my point of view. Realtek HD Audio isn't great but it works fine and they are frequently updating their drivers. VIA directs all support to the vendor which pretty much leaves you with no support at all at least by going with Asus standards regarding driver updates. I've also found VIA audio codecs to be a lot more glitchy than Realtek but that's most likely a driver question than hardware. I'm also not that fond of Marvell SATA-controllers, some like Asrock and MSI uses ASMedia ones instead which also work very well in AHCI-mode.
//Danne
realtek audio with Support for X-Fi Xtreme Fidelity
But Realtek LAN vs Intel is really no brainer...
//Danne
But that's an extra $30 that I wouldn't have had to spend if I had been more careful...sucks.
It's safe to say I will keep my 5Ghz 2500K for awhile until E2 comes out. I'm sure Intel will find a way to improve the IB. So much anticipation/expectation, yet it seems so little excitement now that the OCability has been rumored to be bad.
http://www.tweaktown.com/news/23567/industry_sources_say_ivy_bridge_will_launch_monday_april_23/index.html
So we will soon find out if we can fry our eggs on this CPU or not.
//Danne
I'm wondering what are these QoS features at the NIC level you guys always talking about mentioning intel's network adapters?
I know they support virtual LANs and appropriate quality of service features but c'mon who uses virtual LANs in home environment with compatible ISO level 3 manageable switches and infrastructure?
Or maybe you are talking about something different. If yes please give some hints I could follow.
I'd love to go for the UD3H, but the only problem is that it only has 6 SATA ports. I would actually max out at 6 ports when I put my system together:
BD Burner, 3 SATA HDDs, 2.5" Toaster Bay and eSATA on the front of my case.
I mean, does the D3H have the same quality? What do you mean exactly by SATA power input? Also, does the D3H lack better OC'ing software or whatnot?
Just looked it up, apparently the D3H doesn't support SLI...
Thanks from Santa Clara.Just picked up an Intel DZ77BH-55K. I was teetering between Intel and Asus but my last board was an DX58SO which was rock solid with a overclocked Corei7 920. I know a lot of people overlook the Intels due to stigma they've had in the past but I just feel that the makers of the chipset would make the best board based on it. Besides in i'm Oregon, gotta help out a local company!
If you want the longer warranty, get the ST.
If you'll be using mSATA, get the UD5H.
Well there's a plant here in Hillsboro, actually a lot of companies have plants here in Oregon. I can think of Infocus, HP, Nike, Garmin, Yamasa, Intel, Google right off the top of my head, there's probably more.Thanks from Santa Clara.
Running an ASUS Z77 Sabertooth and working like a charm!
