which wifi router is compatible with apple wifi cards?
Discussion in 'Networking & Security' started by chronic9, Mar 29, 2005.
  1. chronic9
    chronic9 [H]ardness Supreme
    5,859
    Aug 18, 2004
    I heard that the D-Link work well with the airport cards?
    iam most likely getting a ibook if that makes a difference.
    thanks for the info.
  2. LoStMaTt
    LoStMaTt 2[H]4U
    3,185
    Feb 26, 2003
    Any wireless router is compatible as long as it is of the .11b or .11g standard.
  3. redheadfred
    redheadfred Limp Gawd
    253
    Mar 3, 2004
    Yup, I'm on my powerbook wirelessly through my d-link router. works great, even through a floor of cement...
  4. ktwebb
    ktwebb [H]ard|Gawd
    2,046
    Feb 3, 2002
    "which wifi router is compatible with apple wifi cards"
    All of them. By using the term Wi-Fi in your question you answered it. If it's Wi-Fi certified they'll work together.
  5. chronic9
    5,859
    Aug 18, 2004
    i read on some website once that people complained of linksys having horrible reception with their MACs so i just wanted to find out before i buy a new router.
    I guess I can put up my current Netgear RP614 v2 in the FS/FT section now.
  6. Chhhh
    Chhhh Limp Gawd
    445
    Sep 25, 2000
    I have a Linksys WRT54G v2.2.
    I don't like it at all. The third-party firmware is nice, but the reception isn't that great.
    Also, it drops connections like they're hot. Like if I'm transfering files over WiFi, it will just crap out after about 30-50 MB, and require a reset. It seems to work fine for normal use, but it doesnt like file transfers over WiFi one bit.
    So it's going back to Best Buy tomorrow morning, and I'm going to pickup a DLink DI-524 and try one out. I don't think it could be worse.
