Airbrushkid
- Aug 27, 2007
I've only seen 1 card that was in stock on launch day. After that they have been out of stock.
I was able to snag a Gigabyte 4090 Windforce from Newegg on launch day. There were several more than that, but at the time, that was the only one that would fit my case, so I got it.I've only seen 1 card that was in stock on launch day. After that they have been out of stock.
Probably because there is not much difference in performance pushing it to 600W from what I read. Going from 520 to 600w probably doesn't show much benefit.So what baffles me is, why the hell did MSI gimp the Suprim X cards to only 520W?!?!? If anything, they are perfectly designed for the 600W most cards are unlocked for. If there is an unlocked vBIOS for those MSI cards, I'd snag one in a heartbeat.
I am looking for a Founders. If do get one of those. I'll put a water block on it.I was able to snag a Gigabyte 4090 Windforce from Newegg on launch day. There were several more than that, but at the time, that was the only one that would fit my case, so I got it.
Of course, since then, I've changed my case and PSU. It's rather ironic, honestly.
The card I want lol. I will make anyone's problem mine at full cost lmao. But best wishes to you, you get it figured out.I bought an MSI Suprim X 4090 but I can't use it.
I'm experiencing a boot loop issue on my Asus Z690 Extreme board.
There are a lot of other users with my same problem on other forums...
so disappointed.
I mean, I get that, I would never game at that setting. But for an enthusiast card at least give people the option to push it for benchmarking purposes. It's a Suprim X, not a Gaming Trio....Probably because there is not much difference in performance pushing it to 600W from what I read. Going from 520 to 600w probably doesn't show much benefit.
With unigine Heaven at 1080p... Not exactly a good test to check for performance increases.https://www.techpowerup.com/review/nvidia-geforce-rtx-4090-founders-edition/42.html (only 4.5% increase with 12% increase in clock with more power on FE)
Not piss poor at all. AD102 has nearly 20k cores to feed. You have to have hardware to route data in order to get there. This is part of the reason such a high core part might be slower at lower resolutions; the data still has to travel the same distance and go through the same number of stages in order to get to its destination. If the cores are not able to be properly fed, it will be, naturally, slower than a chip will less cores and a less complex scheduler.Using a 4090 at 1080p or even 1440p can result in actual worse performance than the 3090 in some rare cases and that's with the fastest CPUs out there. Nvidia has an absolutely piss poor hardware scheduler. You can even end up in cases where a mid-range AMD GPU matches or beats a top of the line Nvidia GPU if your CPU is inadequate.
Maybe actually read a little bit closer to what I said? It is most certainly a very poor scheduler when your competition doesn't have that issue and can match or beat it with a much slower card. This has been an issue now on the last three architectures from Nvidia. Not only that but their last three generations of higher core counts have unbelievably bad scaling compared to the two previous architectures before that even at higher resolutions. The difference between a 3090 TI and a plain 3080 was laughable considering the difference in specs.Not piss poor at all. AD102 has nearly 20k cores to feed. You have to have hardware to route data in order to get there. This is part of the reason such a high core part might be slower at lower resolutions; the data still has to travel the same distance and go through the same number of stages in order to get to its destination. If the cores are not able to be properly fed, it will be, naturally, slower than a chip will less cores and a less complex scheduler.
Must we do this every time?Maybe actually read a little bit closer to what I said? It is most certainly a very poor scheduler when your competition doesn't have that issue and can match or beat it with a much slower card. This has been an issue now on the last three architectures from Nvidia. Not only that but their last three generations of higher core counts have unbelievably bad scaling compared to the two previous architectures before that even at higher resolutions. The difference between a 3090 TI and a plain 3080 was laughable considering the difference in specs.
This did not start with this generation of card and was clearly a problem on the previous generation and on the generation before to some extent. As some reviewers noted this comes down to hardware scheduler doing a poor job. AMD doesn't have the same issue so if you want to blame it on the fact that Nvidia has more stuff in their chip then go ahead if you think that's the reason. From the user standpoint the hardware scheduler cannot keep up with the GPU even with the latest CPUs and completely shits itself at lower resolutions. If you don't have a top-of-the-line CPU then it's even worse. So whether you believe it's the hardware scheduler or not, the bottom line is NVIDIA needs to fix this issue.Must we do this every time?
Nvidia has a ton more RT and AI hardware to route to than AMD and a wider memory bus. AD102 is far more complex than anything AMD currently has on the market. They are not the same.
Complexity adds latency.
I passed on that despite having opportunity both times, no rush to replace the 3090 and would rather see if my tuf 4090 BH pre-order goes anywhere. I see snailbot is on Twitter with their shenanigans again 🤣So might have scored gaming X trio from Antonline. Had little over $50 premium. Let’s see if I got in. I saw notification on Twitter but was late and it was already out. Then I went on website again 10 mins later saw the gamin X in stock.
Let’s see if it all goes through and don’t get an apology email. But they are not on website at all now. May be I got in on few drops they did.
I do still wanted founders for clean looks for my build or the suprem X . If I score that one from Best Buy I’ll hook up someone here for at cost.
I just don't see this being sustainable given macros fwiw, it's not 2020 with crypto+covid not to mention helicopter money allowing (kid you not) high-school janitors to pay 3k for a 3090 fee.
100% Nvidia wanted this to happen, just look at how AMD pulled off the Zen 4 launch without a hitch (Zen 3 was almost as bad as Ampere during first few months).
My 4090 is slightly larger than the 3090ft3 tiThought stock was plentiful. Wtf happened?
My card should arrive today. Will post nudes then comparing to the monstrosity that was 3090 Ti.
200% scaling is 5430x3054 (16.6 MP vs. 8.3 MP).Well, it was *suppose* to come Wednesday... but I picked it up from Best Buy as soon as I saw that email) -- I ran quake champions at 4k 200%, which is 16k resolution I believe, was about 60-80 fps, so maybe I'll just stick to 100%
Had to pull one fan so it would fit, still running my 800w PSU for now, just threw it in there quick ;o) My Noctua fan isn't in either, need to find some case screws as my previous radiator for GPU was on the exhaust fan
Nope. 200 percent scaling on each axis would mean double on each axis. So 3840x2160 becomes 7680x4320, or four times the pixels as he said200% scaling is 5430x3054 (16.6 MP vs. 8.3 MP).
Never quite understood the appeal of a founders card. Noisy mofos.
TUF is so quiet. Much better than my EVGA 3090 Ti even.
Sounds more like more material for him to make another OUTRAGE video.There is an interesting rumor that Nvidia binned chips for the FE. Jayztwocent reports his FE clocks higher on the memory than his Strix, which carries a $400 premium. Definitely something to consider, unless the rumor is complete BS.
Just people with 0 patience and money to waste.sad to se the FE cards bidding close to 3k on ebay lol. You can't even win with nvidia sending people redemption links, they even selling those. Like if you don't want it people let it go to next person lmao.
Yep.The greatness of the FE this gen is why EVGA exited. So it's no surprise that it's in high demand. Couple that with the fact that it is the most economical price wise and more importantly - sizing wise. It fits more cases.
You clearly are not into water cooling. Those like me who are, prefer the founders cards because there typically is much wider availability of water blocks for them. And with WC, no need to worry about noisy fans.Never quite understood the appeal of a founders card. Noisy mofos.
