which of those 27 inchers should i buy?
mickey11
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236342
http://www.newegg.com/Product/Produ...73&cm_re=BenQ_GW2760HS-_-24-014-373-_-Product
http://www.amazon.com/BenQ-EW2740L-...F8&qid=1409431526&sr=1-1&keywords=benq+ew2740
http://www.newegg.com/Product/Produ...6103&cm_re=Asus_VE278Q-_-24-236-103-_-Product
No games played. Mostly for internet use and movies.
The last one is too old, right?
I kinda like the ASUS VN279Q most... But the Benq Gw2760 seems to be good to, though it looks cheaper and more plastic, but is 80 bucks less...
Which one should i buy?
burningrave101
I've been spending a lot of time reading the reviews for several of these monitors and would go with the BenQ EW2740L or Samsung S27D590P.
If you primarily use it for web browsing and other PC tasks though I would consider 2560x1440 if you can afford it. My reason for looking at 27" 1080p is strictly console gaming.
