Happy Hopping
- Jul 1, 2004
https://www.newegg.com/Product/Prod...7&cm_re=fan_filter-_-9SIA9F93GK7357-_-Product
the above material says 0.22 mm PVC, 29.5 cm x 30 cm
http://www.performance-pcs.com/ultra-thin-0-45mm-pvc-fan-dust-filter-9cm.html
1) so for the above, do we go with 0.22 mm or 0.45 mm, which is better? is that the thickness of the sheet or the diameter of each hole?
Then there is this:
http://www.performance-pcs.com/filterright-140mm-aluminum-fan-filter-uv-red.html
2) is it even wise to use a aluminum filter ? what does everyone use, aluminum or the above mesh PVC?
3) And I suppose this item below, is really no difference than buying a mesh material and cut the right screw hole?
http://www.performance-pcs.com/a-c-ryan-meshx-fanguard-120mm-silver.html
Then there is this:
