Which do you think is better? Onboard audio or a old SB Live?
Cthulhu
I've just been using the onboard audio...but i have a old SB Live in the closet. Do you guys think that it would be better than the onboard audio? and no, i'm not going to buy a new card. so don't even suggest it. :p
skudmunky
My SBLive sounds way better than my horrible onboard. Why don't you do a comparason and see what you like better. SBLive will also give you options like EAX and CMSS3d. I'd say try it out.
IanG
imo recent onboard sound, especially azalia sounds just as good as an old soundblaster, and you won't have to worry about creative drivers. Most onboard solutions can do eax2.
Cthulhu
cool... maybe i'll try it out. what about performance? would having a dedicated sound card help in that respect at all?
TeamStrykerCore
It just depends on what chipset you have. Performance is generally not bad at all. You might want to check mobo reviews. I remember back in the day and especially on this site where they used to measure CPU usage off the sound and review the chipsets (northbridge etc) especially on the earlier nforce sound setups. I believe the new chipsets should fair better. Unless your old SBlive card was a top of thel ine creative card.
aldamon
Which version of the Live do you have? What kind of speakers do you have? The Live I owned a few years ago was only 4.1. The Live 5.1 came out later. If you have 5.1 speakers, a 4.1 soundcard isn't going to cut it.
Of course. Onboard sound uses your CPU for everything. The Live can accelerate EAX 1 and 2 with very little CPU hit. It's a waste to have a perfectly good Live sittting in your closet.
SJetski71
Pop it in, install the drivers and test it out.
Won't take more than a few minutes ;)
Cthulhu
yeah, i really dunno why i never put it in... i don't watch movies or play TOO many games, so it never really crossed my mind to install it. i think i'll put it in tonight. thanks for the replies... :D
Cthulhu
hmmm.. i just ordered some new speakers, which is why i started thinking about the card in the closet. the new speakers are 5.1. so i'll have to check out the card when i get home...might have only been the 4.1 variety. if so, guess i'll just keep using my onboard sound. :)
