My GTX580 can't play Just Cause 2 or AvP smoothly. If it drops under 60 it's not smooth to me. I'm going to go SLI when I get my Sandy Bridge.
SLI won't help you, you need more vram...
More than 1.5GB?
I'm using a GTX 480 for 2560x1600 gaming. But i'm thinking of switching over to a 6870 due to more vram. Anyone think this upgrade is worth it?
Well it will help for a start. Especially when you throw anti aliasing into the picture.
Looking mainly at 6970, 580 or 6870 CF setup.
Opinions?
We're in the same boat. Waiting for the HD 6990
Unless you're planning on going quad CF later, or are using a mATX system so only one PCIe slot, I would say go with two HD6950s, or possibly two HD6970s.
Apart from being impossible to find, a GTX580 is considerably slower than two HD6950s, and again, is borderline enough video memory for the worst current games at 8xAA+.
SLI with GTX570s is all well and good, but you're using in excess of 500 watts to do what again, two HD6950s will do better for a lot less cost and wattage. ($600 vs $700, 340W vs 450-550W).
No he doesn't. Stop throwing around FUD when you can easily check these things using MSI Afterburner to monitor vRAM usage.
You know you need more vRAM when everything starts stuttering and you can barely exit the game before you're forced to reboot.
If you're not using supersampling AA, there's almost no game that requires you to have "more vram" at 25x16 so long as you have 1.2GB or more. 99% of the time it's a horsepower issue way before it's a vRAM issue.
Crysis Warhead at 4x MSAA with all options maxed is the only game that's maxed out my vRAM at 25x16, and that's on 470s, not 580s.
Don't discount the allure of Eyefinity, either. You never know... maybe that 25x16 is only temporary . In which case 4 gigs of memory might come in handy.
-HD
-HD
