Which AsRock B660m Steel Legend drivers?
Operaghost
I've never owned an AsRock product before, but I have a B660M Steel Legend arriving today for a new rig I'm building (first one in over a decade, /gasp).
So I figured I'd download all the drivers I'm going to be installing, but I find their descriptions on the download/support page to be quite non-descriptive/confusing.
Was hoping someone could help me out by suggesting WHICH drivers off this list I should install after I have Win 11 installed/updated.
Here is the AsRock list of drivers: https://www.asrock.com/mb/Intel/B660M Steel Legend/index.asp#Download
And here is my other hardware for reference: https://au.pcpartpicker.com/user/NorseKnight/saved/VprLcf
Thank you in advance for any feedback. I'm a bit out of the [H]ardware loop/tech.
Operaghost
Think I answered my own question after a bit of research. Seems like the only drivers I actually need off this list are the Realtek audio and the two LAN drivers.
Operaghost
Upon further review, I don't think I'll be installing any of these drivers manually. I'm just gonna let Win11 do its thing....
pendragon1
Extremely [H]
youll still have to install the chipset driver and probably ime and possibly a serial i/o driver from intel not asrock.... the two z690 system i just loaded 11 onto was still missing 6-8 things after installing all updates/optionals.
Strange bird
Nice computer, I like the choice of parts, congratulations㊗️
I'm not familiar with the new intels, but be sure to install the intel chipset drivers, there is probably also a program for intel nvme ssd, so be sure to install that as well.
Probably the monitor also has its own drivers and be sure to install them after you install the amd drivers for the gpu.
That's what comes to mind for now.
Operaghost
Thanks for the replies folks, I'll be on the lookout for those.
Operaghost
Intel doesn't have any drivers on thier site for the B660 that I can find.
Operaghost
and possibly, you'll see what you're missing when you start everything
Yeah, I literally only updated the GPU driver. However, device manager is showing both secondary PCI Slots as not working. Which is surprising...
Strange bird
Maybe some setting in the bios, flash the latest mbo bios.
First gpu drivers and then windows update as long as it is available.
Then, after that, see what needs to be done and what else is missing, ssd drivers,realtek,lan etc...you can download it from the asrock site
pendragon1
Extremely [H]
grab the hardware id and see what it is. it might be part of the ime i mentioned.
