My new case came with a trio of screaming 120mm Deltas. I also realized after I got it that the thing has 2 mounts for a pair of 92mm fans up in front of the HD bays. I've got 5 fans on order, and they've all got temp probes & manual adjustment knobs. Now I just need to decide between the temp probes and manual adjustment, and where to put the temp probes.
The case is a Chenbro SR10769-BK. It's a dual Opteron system with a 6800GT.
As for the fans I've got 3 120mm and 2 90 mm fans on order.
All I'm trying to figure out here is where to put the thermal probes. Anyone have any advice on this?
So far I'm thinking I'll put the probes for the 2 middle fans on the CPU heatsinks and the exhaust fan probe on the 6800GT. Anyone have a thought on where on the 6800GT would be a good spot? It's got a heatpipe on the cooler... maybe there?
I may just use the knobs for the 90mm fans in the front of the drive bays. Even at minimum fan speed the drives would probably never get warm enough to kick the fan up a notch, and attaching the probes or control knobs anywhere but on the removeable drive cage would be a major PITA.
