Where to buy a 24u rack?
Discussion in 'Networking & Security' started by Bviper, May 18, 2009.
  1. Bviper
    Bviper [H]Lite
    117
    Oct 20, 2008
    I remember reading someone posting a good place to order racks, but for the life of me cannot find it and Google is of no help.
    I am looking for a 24u rack to hold two 2u servers, a patch panel, and maybe a switch. I am not sure if I need a 2 post or 4 post rack. This is for home use so I'd like it to be as inexpensive as possible.
    I've been searching craigslist, but not many in my area. Any suggestions?
  2. vapb400
    vapb400 Gawd
    786
    Sep 19, 2004
  3. Bviper
    Bviper [H]Lite
    117
    Oct 20, 2008
    Yeah, those were the ones I was looking for. It's amazing how much better their prices are than other places.
    Look's like I'll be ordering this here soon.
  4. QHalo
    QHalo 2[H]4U
    3,432
    Sep 30, 2002
    Can't go wrong with a Skeletek rack. Good stuff.
  5. Orinthical
    Orinthical [H]ard|Gawd
    1,635
    Jun 7, 2004
    I don't want to rain on your parade but unless you plan to put your servers on the floor (or on-top of a UPS unit, which is on the floor), you are most likely going to need a four post rack. Many servers, unless they are the 1U half-depth variety, are too heavy to mount in a two-post rack which is commonly reserved for communications/network equipment.
    You'd likely be better off with something like these (from the same retailer):
    http://www.dantraknet.com/item/85
    http://www.dantraknet.com/item/72
  6. Vito_Corleone
    Vito_Corleone [H]ard|Gawd
    1,730
    Dec 17, 2006
    I have a 24u Skeletek and it works great for my Cisco ish.
  7. marley1
    marley1 [H]ardness Supreme
    5,447
    Jul 18, 2000
    Dell 2410, good deal right now 675 I believe.
  8. Ockie
    Ockie *** Self Proclaimed Storage King ***
    17,991
    Mar 2, 2005
    gruber.com sells great products.
  9. k1pp3r
    k1pp3r [H]ardness Supreme
    7,891
    Jun 16, 2004
    If your holding servers you need a 4 post, not that 2 post.
    I honestly got my 42u IBM rack off ebay for around 400 with PDU and 2 shelves.
  10. Ockie
    17,991
    Mar 2, 2005
    A two post is fine if you have center post brackets for your rails. Or if you use a shelf.
    Ideally a four post is much better but then you are either spending a lot of money or finding yourself on ebay/craigslist.
  11. Bviper
    Bviper [H]Lite
    117
    Oct 20, 2008
    The four post isn't that much more expensive, but kills the plans of putting a mid-tower and UPS on the floor.
    Somethings awry, http://www.dantraknet.com/item/85 lists as one set being 20U and the other 16U. But in the description, it references 8U?
    "HD8U-EX Dimensions: 21.5" high x 24" wide x 30" deep 2.0 MM frame thickness "
