I'm interested in getting a Trusted Platform Module (TPM) for the new desktop rig that I am building, mostly for enhanced security with BitLocker. Currently, I'm looking at the Gigabyte GA-Z68X-UD3P-B3, which has a 20-pin TPM header.
Does anybody know where to buy a TPM? I am told from different sources (Gigabyte tech support, Asus tech support, etc.) that the connector is standard and therefore I can just go out and buy it "anywhere". Unfortunately, a search online has not uncovered a hug trove of TPMs just waiting for the buying.
Of all TPMs, only the Infineon TPM has been certified by the Trusted Computing Group. I would like to avoid others for fear of backdoors. I found this one but if you look closely at the pinout diagram, it differs slightly from documentation from several motherboard manufacturers--I checked Gigabyte, Asus, and Supermicro. So, I have no idea if it will work or not.
