Your assertions that 70% isopropyl alcohol is not pure enough, that even a fingerprint will lead to higher temperatures, that using 70% alcohol to clean can result in slightly higher temperatures, and that these "microscopic particles" affect heat transfer in any meaningful way.burningrave101 said:Whats to substantiate?
If the technique is to use the alcohol to soften the material, dissolve it, and then wipe it off, why does evaporation rate matter? If evaporation rate matters, at what point does a higher temperature or lower relative humidity overcome the lower concentration of isopropyl alcohol?
What is this residue composed of, and why does it not completely wipe off? How much do you think it affects the themal resistance of the interface between the spreader and the heatsink, quantitatively?
Maybe you're right, and I'm not challening that. I'm just trying to figure out if you really are, and why.
That's interesting, but it doesn't prove anything. It's a fallacy to think that, because something is common practice, it must be correct.burningrave101 said:I did a google search a minute ago and found several threads on different forums where users said the same thing.
