where can I find replacement modular pci-e cables for a Antec TPQ 1000?
Airbrushkid
Hi,
I'm trying to find 2 - replacement modular 6 pin to 6 pin pci-e cables for a Antec TPQ 1000? I tried Antec but they stop making this power supply. Does any one know of a place or any one have any of these they like to sell?
Thank you for any help.
If push comes to shove you can get the connectors from a place like frozencpu, use a multimeter to work out the pinouts and build your own cables.
Show us a picture of the connector with the wires coming out of it. such that we can see each pin of the connector and we can tell what color wire is going to each. this sort of profile except with the actual wires (stick 2 or 3 fingers between the 2 rows of wires to separate them). Make sure no wires are crossed in the picture. We need to be able to clearly see which wire goes to which pin and if any are crossed, we may give you a suggestion that blows up your power supply.
You can also check Antec's spare parts store: http://store.antec.com/parts/
