i did 1.6v on my venice, i've gone up to 1.6v on my x2, and i've hit 1.65v to do 2.8 on my opteron 170... but the majority of people would think its too high lol, i'm just not real scared of breaking anything, not that i have deep pockets, but i have a backup p4 rig in case anything happens, plus i still have my x2 3800+ lol... 54C sounds like a pretty good load temp to me... i'm running 47C as we speak dual F@H on this machine, with 1.53v...gags said:ok cool,
so do you think 1.55 vcore is to high on air?
my temps are 54c full load prime 2 cores
i need to try 2.6ghz before this opty goes in the bin
when you hit the mhz limit of the motherboard. this shouldn't be an issue though, as i've yet to own board in the last year that couldn't break 400mhz with stock chipset voltage.gags said:When do I raise my chipset voltage?
Budwise said:CCBWE are mostly dual core chips. All the DC Opterons are CCBWE so far...
Elysian said:maybe its just you're cooling is poor? or maybe you just got a weak stepping? what HT ratio are you at? should be at 3x.
you're running your HT link out of spec. it is not a good idea to go over 1000... but if yours is prime stable go for it.RegisteredToPost said:My 175 is at 2.7 with HT 4x. What is the reason for setting 3x? I figured i could get a higher clock with htt at 4, and less HTT
and you're not running at 270.RegisteredToPost said:i'm not over 1000
