When my cable internet gets slow, I have to unplug my router and plug it back in...
Discussion in 'Networking & Security' started by bobsaget, Sep 27, 2004.
  1. bobsaget
    bobsaget [H]ardness Supreme
    4,403
    Jan 24, 2004
    When my cable internet just doesn't work or gets extremely slow, a simple unpowering the router and plugging it back in fixes that problem.
    Is this because the router isn't on a surge protector? How can this constant unplugging/plugging back in problem be resolved?
    Thanks!
  2. MiXdNuTs
    MiXdNuTs Gawd
    827
    Aug 9, 2002
    Sounds like you have a Netgear router. I'm thinking probably model WGT624. These seem to have a flaw with the SPI firewall which is on by default. Netgear won't admit to the problem, probably because that would me a MASSIVE recall, but I did get them to admit to me I had to dissable the SPI firewall to fix the router crashing. Try disabling the SPI firewall, but don't worry because you will still at least have a NAT firewall.
  3. Karandras69
    Karandras69 [H]ard|Gawd
    1,857
    Feb 16, 2001
    Are you running and P2P software? Could be disconnecting everyone and then they slowly connect again and you get slow again. Try to disable all that stuff.
  4. MiXdNuTs
    MiXdNuTs Gawd
    827
    Aug 9, 2002
    Good call, I didn't think of that.
    Try turning off uploading.
  5. Karandras69
    1,857
    Feb 16, 2001
    Depending on how much he is downloading, will want to turn the entire program off.
  6. bobsaget
    4,403
    Jan 24, 2004
    No, it is a Linksys with wireless B...
    I have not run any of that software in years...
    How would I do that?
    Thanks for all of the feedback and suggestions so far! ;)
  7. MiXdNuTs
    MiXdNuTs Gawd
    827
    Aug 9, 2002
    By uploading I was referring to P2P file sharing.
