What's the best graphic card?
Relayer
You need to be more specific. We have no idea what would be best for you.
System specs, budget, and usage type, please? If gaming, what games?
ssnyder28
Also what resolution are you planning on running the monitors at. Running 3 monitors at 1080p vs 4k are going to require substantially different gpu power.
gersson
I have had both semi highest end cards availble in the begining of this year.
780 ti
and
290x
I loved the 780ti but since I am a battlefield fiend, I swapped it for a 290x to try mantle. I have barely noticed the difference but in return I got to save $150 BUT even though my 290x is a Sapphire Tri-X it is still pretty damn loud.
they both have the ups and downs though my tilt is now 780ti since mantle is not really as big a deal (for now) as I thought it was.
bernaby
I love my 780Ti but I have to admit now that the prices have returned to normal the 290X is a better value. Do yourself a favor and go for one of the non reference cooler models.
tonyftw
For 3 monitors, I would recommend amd's 290x (2 preferably). Bigger bus and extra 1gb of v-ram will come in handy.
fanboy
780 ti
and
290x
Mantle is still a beta and unknown what the limits are yet and we know Intel wants it for testing as well as others .. so it's still a big deal.
If the OP can do crossfire then 2 x R9-280 is the sweet spot as it would be cheaper and faster..
The Mac
yeah, those are high end.
Only thing higher are the Halo products (295x, Titan, TitanZ)
rhansen5_99
Yeah either a 780ti sli, 290x crossfire / 295x or the ludicrous TitianZ are the best as of yet
KazeoHin
AMD 295x2 holds the "fastest single card for gaming, damn the budget" title for now.
darme
I'm still rocking my 690, though 3 monitors would need way more vram at that resolution.
GameHard6
Go with the Sapphire R9 290X TRI-X OC http://www.amazon.com/gp/product/B00HJOKARI. The bus size and VRAM are excellent for a triple monitor setup.
With the high resolutions you have, you won't run short like you would with only having 3GB VRAM. You may, however, want to go SLI and if you go that route the 290 may be a better choice.
