First off, here are some specs:
AMD II X4 955
MSI 790x-g45
16gb of Crucial Ballistix @ 1333
2x WDC 1501FASS 1.5tb
1x Kingston HyperX SH100S3-120gb SSD
Ultra X3 800w PSU
I previously had two WD 750gb hard drives that I ultimately replaced due to bad sectors. Well, here we go again. Both my WD's are proving to be on the way out with quite a few bad sectors. The SSD is fine, but I've had issues copying data to my WD's (data is backed up).
Normally I would think I'm simply unlucky, but 4 hard drives in 3 years seems to be a bit absurd. I never had an issue with WD hard drives before and I find it hard to believe that regardless of the manufacturer that I would string together 4 bad drives in a row (even though the first 2 were a couple years ago).
The previous hard drives were in this same computer, which is why I have a feeling something here could be causing an issue. These hard drives aren't new by any means (20,000+ hours), but I don't believe that's grounds for failure.
Crystal Disk Info has both drives labeled as caution with an alarming amount of uncorrectable sectors and I was unable to perform a SMART test with WD LifeGuard.
Any input would be appreciated while I look for what my next storage drives will be.
AMD II X4 955
MSI 790x-g45
Ultra X3 800w PSU
