Hello,
For a while now I've been having serious problems with my new computer. At random times (anywhere from once every 6 hours to once every 30 seconds the computer will bluescreen and restart). I am currently running windows vista but in the past I've run windows 7 and there have been multiple OS installs all with the same problem. At this point I have swapped out or simply unlpugged every piece of hardware I have except for the motherboard, powersupply unit and the cpu. I can't swap those out without buying new.
I thought it was the motherboard and sent it in for RMA. It came back a few days ago and at first it seemed like it was fine. But it just bluescreened on me again so I know that didn't fix it. The motherboard came back in a box without any paper at all. So I have no idea if DFI fixed it, or tried to find a problem and couldn't so they just sent it back.
My computer tends to bluescreen at weird times, I can play fallout 3 for hours with no problem then when surfing the web with only 2 browsers open it will bluescreen.
So my question is this: what is most likely causing the problem? Is it my Mobo? PSU? or CPU?
If I know what is most likely the problem I can buy new parts and test those out, but I really don't want to buy all three new. Thanks in advance for any advice.
BTW here is my complete build.
