I dont want to get one that I have to install into the notebook/laptop, I want to get one that is USB, are there any good ones that you guys can recommend? Thanks
My personal recommendation would be fore the AverMedia UltraTV USB 300.
Your options are quite limited when dealing with USB TV receivers, unfortunately.
Hauppage also makes a couple of USB ones, but they're not spectacular by any definition.
