Not sure why you would go from a 6 core to 4 core from what ive seen there is no benefit going from a 3930k to a 6700k if anything its a downgrade
i would say its a huge upgrade when it comes to gaming,
Clock for clock there pretty neck and neck this in noway would be a huge upgrade in gaming,infact im pretty sure in big rts games like the total war series you wouldnt get stutter with the 3930k like you would with a 6700k.If 5-8 percent better performance clock for clock is a huge upgrade for you then so be it,however i seen videos where in certain games the 4 core has noticable stutter where the 3930k just breezes right through it.Like i said i consider it a down grade no reason to go 6700k if you already have a 3930k
So that means these multicore and highly threaded processors can actually give less performance in heavy gaming workloads than their siblings when it comes to DX....in Ashes of the Singularity. It certainly does seem that the issue is seen on the Fury X system much more than our 980 Ti system.
Not just gaming in my case. Skylake has cut my hevc encoding times by roughly a 1/3, at a lower clock while using a bit less power. And I'm moving away from quads so who needs all the lanes?
If you have have the money to buy a skylake then why would anyone choose that over a 5820k for pretty much the same price? 2 extra cores for 50 bucks more and a better gaming cpu on top of it.It doesnt clock as high as the 6700k but from this test a 4 ghz 5820 matches and beats a 6700k skylake clocked at 4.7 ghz. so to say having 2 extra cores doesnt help some games nowadays is ignorant
Intel Core i7-6700K 4-Core 4.0GHz compare Intel Core i7-3930K 6-Core 3.20GHz CPU
I rest my case and thats with the 6700k having an 800 mhz advantage in clocks you run them both at 4 ghz steady and the 3930k is quite a bit better then the 6700k.
That's great you feel good about your procssor howe very wheb gaming at 2560x1440 with a gtx 1080 a 2500k sucks and is no where even the speed of a 4790k haswell at 4.8ghz . Also dolphin emulation on any ivy chip sucks and it clearly shows IPC in the newer processors are just plain better for triple A titles GTAV as an example. Your min and max frame rate will sufferIt's adorable how people seem to think you need a new CPU to hit reasonable framerates in modern titles. Sorry bros -- still happy with 60Hz and zero reason to give the 2500K up yet.
the 5775C is better than the 6700k and its even clocked lower. Check out Techreport's 6700K review. or some of the broadwell specific reviews. It seems that EDRAM loves acting as extra CPU cache, in games.
Lmao, what case did you make?
its as good or better, in the 5 games they tested. 3 of which, were tested with real gameplay sessions. not built in benchmarks. and that's at stock clocks, which are lower than the 6700k. I have seen some specific game tests on other sites, where the 5775C does lose a little bit. But we are talking two or 3 frames. And that's at stock clocks. and those same sites or videos, also show many other games, where the 5775C is at least as good.In one or two scenes for less than a second . It's like 2 games but then the 6700k pulls ahead
5775c is only great for professional or business programs that are used for a JOB. Other than that stay away from it
Both can be overclocked, so the benefit of the EDRAM would still persist, even after overclocking. and in that sense, you could match or closely match clocks with a 6700k. Matched or closely matched in clocks, the 5775C should nearly always be better.
The only times it might be worse, are weird games where bandwidth is strangely more important, than usual. So the Skylake memory controller and DDR4, takes the lead. Weird games like Fallout 4 or Ryse.
Intel's Core i7-6700K 'Skylake' processor reviewed
If i really have to tell you that then your not all thereLmao, what case did you make?
If all you can do is resort to ad hominem, get lost.
please show us even 2 proffesional reviews comparing the two you seem to talk alot yet show no proof atleast i showed you a comparison showing your wrong a skylake loses to that 4 year old cpu and it has to run at higher clocks just to keep up.Thesmokingman i apologize if i offended you im more calling out unrealcpu telling everyone it would be a huge upgrade to go from sandy bridge e to skylake it is simply false.heck there isnt even a real reason to upgrade from a 2500k unless you just have to have ddr 4 memoryIf you say so lol
I guess all the professionals reviews are wrong then. This guy
Please show me where any 6-10 core processor is worth getting for gaming in this review
Pro reviews have been posted, one of which is [H]'s comparo of the 10 core 6950X and the 6700K in the most threaded large scale rts bench queen/game made, Ashes. It found that the 6700K was no slouch, even faster than the 6950X at same clocks.
You keep throwing up dubious info to make your point then have the audacity to demand pro reviews. I feel you're just going to ignore the pro reviews again. Are you saying that your 3930K is faster than a 6950X?
I threw up 2 links with facts now 3.im not acting like a 3930k is the end all cpu all im trying to say is they compare well to skylake and will beat them alot of the time so therefore it is not worth the upgrade i dont get what your not understanding about that?It simply would not in the least make sense to go from a 6 core to a 4 core when dx 12 is coming out which is sounding more and more like it will take advantage of more cores.By going skylake you are not future proofing unless your ok with playing in dx 11 the duration of the time you keep it.
please learn something seriously you have showed nothing now eerything i throw up is random ok now i can smh.then i get a video from cpu guy showing some old amd cpu's comparing to a 6700k lol give me a break.this is all you guys can come back with atleast i bothered to watch cpu's video and it was a waste of time showed nothing about a 6 or 8 core intel against the skylake the guy doesnt even watch his own video before posting and i should take you 2 serious?really?I showed you links with benchmarks actually comparing the 3930k clocked at 3.2 ghz against the 6700k clocked at 4 ghz and the 3930k was 3% faster your the one pushing everything aside that i link.your both clueless and really give bad advice telling someone to upgrade there 6 core for a 4 core when the 6 core games just as good and does everything else faster.Another thing you convienantly leave out is that the 6700k is clocked a whole ghz higher then the 6950x see how that works?when you add that in there it isnt looking so clear cut anymore is it?show me a clock for clock comparison and ill show you the 6950x on top.I wouldnt buy one of those anyway there way to expensive but i would however easily buy a 5820k over a 6700k anydayYou really have a hard time with a reasonable debate. Again, yapping about DX12, yet ignoring that the 6700K is actually faster in DX12 Ashes versus a 6950X. On the flip side your posting of random utube videos, specs list, and random chart does not make it valid data. End of the day only a fool would suggest a 3930K is better than a 6700K when even a 6950X already has its hand full. LOL, want to play games, try a 5775C on for size since it has the best IPC.
If anything its a downgrade? Yea, ok... smh.
smh
Is that all you got?Now instead of trying to avoid the subject please explain why you posted a video that didnt show anything that even remotley fit the conversation?Its sad you post multicore amd cpu's against skylake to get your point acrossed sorry but you failI agree 3930k is a obsolete eND of life part and not suitable for gaming
I'm upgrading from a i5 6600k to i7 6850. I know that everyone says that it will make zero difference in gaming but I'm not listening to those folks. I think it will make a difference.
