what your buying, Intel i7 6950X , i7 6900K , i7 6850K or i7 6800K?
Discussion in 'Intel Processors' started by AndreRio, Apr 29, 2016.
which new processor are you getting?
  1. Intel i7 6950X
  2. i7-6900K
  3. i7-6850k
  4. i7-6800k
  5. old and cheaper: 5960x
  6. i7-5930k
  7. i7-5820k
  8. i7-6700k
  9. i7-4790k
  10. cheap i5, i3 or amd?
Results are only viewable after voting.
  1. Criticalhitkoala
    Criticalhitkoala [H]ard|Gawd
    1,670
    Apr 17, 2015
    I was able to get a stable 4.8ghz all cores oc on my 5930k the last month, but I think I'm gonna move it into a itx box and get the 6900k for the main rig for editing.
  2. chineseman
    chineseman [H]ard|Gawd
    1,218
    Mar 28, 2004
    What motherboard/ram are you guys planning to use with these? I picked up an 6800k today and I haven't upgraded in forever so I have no idea what's what. I'm thinking of getting the Asus ROG Strix X99 Gaming but I have no idea what ram I should get to go with it.
  3. Vader1975
    Vader1975 Gawd
    818
    May 11, 2016
    I'm going to wait for the AMD Zen to see what they can deliver. If it's a reasonable combination of price and performance then I'll go ahead and get one.
  4. HAF72
    HAF72 1337 :)
    7,362
    Nov 2, 2006
    I plan to get the MSI x99a gaming 7 motherboard with gskill 3000mhz ram
  5. EuphoricRage470
    EuphoricRage470 [H]ard|Gawd
    1,108
    Apr 15, 2011
    I'm going with an X99-A II from ASUS, and a 64GB Crucial DDR4-2400 kit.
  6. Porter_
    Porter_ [H]ardness Supreme
    7,858
    Sep 10, 2007
    it's always a safe bet to choose ram from the vendor's QVL list. i did this for my Sandy Bridge build and have never had a single ram related issue. i did the same (ordered off the QVL list) for my incoming Skylake build.
    chineseman and kalston like this.
  7. chineseman
    1,218
    Mar 28, 2004
    I never knew they had QVL's for motherboards...derp...learn something new every day :D. I'm actually thinking of returning the Broadwell-E build and going with Skylake as well. Just got caught up in the hype but if I'm being realistic, I don't do anything that would require more than 4 cores and 99% of my game time is playing Dota 2 and Overwatch anyways.
    Porter_ likes this.
  8. Porter_
    7,858
    Sep 10, 2007
    eh who knows those extra cores may come in handy down the road. for me, and my purely gaming rig, i was staring at two options for the same price: 1) 6700K + GTX1070 SLI, or 2) 6800K + GTX1080. i chose the 6700K GTX1070 SLI build.
  9. Michaelius
    Michaelius [H]ardness Supreme
    4,684
    Sep 8, 2003
    6700k -
    we are starved for cpu performance in DX11 so every bit of IPC and clockspeed counts
    DX12/Vulkan will reduce cpu requirments so there's much smaller need of trading performance in DX11 for it with 6 cores
    I'm not touching windows 10 turn as long as I can so DX12 hardly matters to me and Vulkan just started
    It's cheaper than 5820k and much cheaper than Broadwell-E, mobo is cheaper for them too
    And last but not least Broadwell-E turned out to be overclocking disaster
  10. sethk
    sethk [H]ard|Gawd
    1,623
    May 3, 2005
    I thought only the E5-1xxx v2 CPUs were overclockable (i.e. multiplier unlocked) - are the v3 and v4 unlocked too?
  11. drescherjm
    drescherjm [H]ardForum Junkie
    14,424
    Nov 19, 2008
    I have not seen E5 16XX V4s listed.
  12. arestavo
    arestavo [H]ard|Gawd
    1,420
    Mar 25, 2013
  13. Wade88
    Wade88 Limp Gawd
    197
    Jun 21, 2015
    Hello, I did not vote because my X79 board died in March, was hoping to get it through to broadwell-e launch but it was not to be so. Acquired 5930k, Gigabyte GA-X99p SLI mb, samsung 950 pro 512GB, and 4 16GB sticks of gskill 3,000mhz ddr4. Seems similar enough to x79/3930k with same quantity of ram, is somewhat more power efficient, and pcie 3.0 x4 ssd's are nice, as is type c usb for rapid charging nexus 6p and maybe a TB3 DAS device in the future.
  14. GothamsReckoning
    GothamsReckoning Limp Gawd
    243
    Dec 22, 2015
    Going from 3930K to 5930K is a moderate jump in IPC and overall performance. However because it's only two generations behind (SB-E then IVB-E and then HW-E) it's maybe on average ~13% at the most from SB-E to HW-E compared with IPC gains and improvements over Gulftown to HW-E.
    The Intel Haswell-E CPU Review: Core i7-5960X, i7-5930K and i7-5820K Tested
  15. caltech31
    caltech31 Limp Gawd
    141
    Feb 8, 2016
    The 3930k could probably overcome alot of the difference in IPC because of higher overclocking headroom.
    The Sanybridge CPUs were the last really great overclockers - a 6-core sandybridge at 4.6+ Ghz is probably comparable to the 6800k
  16. GothamsReckoning
    243
    Dec 22, 2015
    I would agree that. It's too bad that the 3930K and the 3960X only came in 6-core versions and not 8-core versions until the 5960X. Ivy Bridge-E CPU's were also decent overclockers but Sandy Bridge-E still offered the most headroom. With the 5930K/5960X the headroom is even smaller than similar Ivy Bridge-E or even Sandy Bridge-E variants. Some of that could be probably explained by the higher TDP of 140W versus 130W on SB-E/IVB-E.
  17. Wade88
    Wade88 Limp Gawd
    197
    Jun 21, 2015
    Yeah, I wouldn't have upgraded if my Sabertooth x79 hadn't died with 3 months of warranty left. X79 build is now the backup.
  18. Okay, Socket 1151 is a "dead end", but 2011-v3 isn't?
  19. drescherjm
    14,424
    Nov 19, 2008
    1151 is the only socket from Intel or AMD that is not a dead end. Although I admit upgrades will likely not be worthwhile for most with the IPC increases of recent times.
  20. SomeGuy133
    SomeGuy133 2[H]4U
    3,447
    Apr 12, 2015
    False. It should be 18% for SB-HW. SB-SKL is 25% and HW-SKL is 6%.
  21. KG-Prime90
    KG-Prime90 Limp Gawd
    251
    Apr 29, 2013
    I'm looking at upgrade from i5 3570k. Never even overclocked it as it basically did everything i needed just fine and i never got around to getting an after market cooler. But i could stand to move to an i7 for multithreading, i don't game so much as i use 3d apps an game editors.
    I would really like a 6 or even 8 core but not sure the power/cooling requirements and the cost are entirely justified since i seem to be getting by with an i5 already. I'm also on a raptor 10k rpm spinner still. I was thinking just getting an ssd and finally an after market cooler and overclock would be huge upgrade in performance on what i have already.
    But i'm itching to at least get some multithreading and better HDD performance...M.2!
    I've totally skipped sata ssd's, and now M.2 is the new thing, and i'm itching to upgrade basically because i have a chub for M.2. lol.
    A 6700k platform seems to be the best bet in price performance from reading around. I know 6 or 8 is "better" but how much really? I don't do sli so 20 lanes is seemingly plenty. 140Watt cpu just seems excessive. Hell i was using a core 2 duo and a 7200 rpm spinner until 3 years ago o_O
    I recently purposely tried to get my system to tank by running a render with music playing, and trying to play Doom 3 HD modded all at the same time, and while it did chug and sputter i could still play the game, though it was not optimal at all.
    But that's not even a scenario that i would be under generally.
    So, question for all the xenon and 6/8 core users. If i just got got an i7 ddr4 and an ssd, and basically tried the same thing, do you think it would be noticeably better? How about a 6 core? Would it still stutter under load like that? How many of you are even truly utilizing 8 cores and 40 lanes that aren't running servers or doing extremely heavy tasks like code crunching or video processing or heavy 3d renders?
  22. GothamsReckoning
    243
    Dec 22, 2015
  23. Skyblue
    Skyblue Limp Gawd
    259
    Jan 2, 2008
    Mathematically, you would multiply the two numbers for a total of 13.42% improvement.
  24. SomeGuy133
    SomeGuy133 2[H]4U
    3,447
    Apr 12, 2015
    not according to anandtech unless E has some magical IPC changes in arch...arch IPC should be the same on all of them.
    The Intel 6th Gen Skylake Review: Core i7-6700K and i5-6600K Tested
    1*1.058*1.112=1.176496 so ~18% SB to SKL is ~25%
    EDIT: interesting...why does E vary so much in IPC compared to quad? its the same design no?
    I would have assumed SB/SB-e would have same IPC...why different? SB-e/IB-e have better Memory BW and was less shitty?
  25. ryan_975
    ryan_975 [H]ardForum Junkie
    14,150
    Feb 6, 2006
    HEDT parts have quad channel IMCs and more shared L3 cache per core
    For example: a 2600K has 8MB to share across 4 cores and could transfer up to 25.6 GB/sec from main memory , while the 3960X has 15MB to share across 6 cores and could transfer up to 51.2 GB/sec. This means HEDT parts can do a better job at keeping the cores filled with data to work on, which reduces the amount of time they're waiting around to get what they need. However, moving data around is only part of the IPC equation, so upping the memory bandwidth or increasing cache availability will have a somewhat limited effect.
    SomeGuy133 likes this.
  26. M76
    M76 [H]ardForum Junkie
    9,224
    Jun 12, 2012
    None of them. I expected that the new generation will bump / core pricing one step lower. Instead they just added a new step on top, and a ludicrously expensive one at that.
    I'll buy when I can get 8 cores with decent clocks for single threaded performance 600-ish. Until then fuck intel, and their monopoly.
  27. Nathan_P
    Nathan_P [H]ard DCOTM x2
    3,374
    Mar 2, 2010
    None of the above, I'm either going Skylake E or E5 skylake xeon when I finally retire my dual x5670 setup
  28. SomeGuy133
    SomeGuy133 2[H]4U
    3,447
    Apr 12, 2015
    if what you said is true thats interesting. All the more reason I wish quad cores had more love :/
    or the HEDTs were not a gen behind.....
  29. UnrealCpu
    UnrealCpu 2[H]4U
    2,736
    Jun 20, 2003
    I have a question regarding the 6900k.. Since i have never owned a processor more than 4 cores. Currently i own a 4790k at 4.7-4.8 and was wondering if i had more PCIE lanes does this mean I can copy more files quicker to external drives or even multiply copies from one hard drive to another? I am talking 20-40gb files
  30. Criticalhitkoala
    1,670
    Apr 17, 2015
    was on the virge of getting a 6900, but someone locally was able to get me a 5960x for less than 7 bones. I had to jump on it.
  31. UnrealCpu
    UnrealCpu 2[H]4U
    2,736
    Jun 20, 2003
    i would have sold you my 6900k for 850
    Criticalhitkoala likes this.
  32. ryan_975
    14,150
    Feb 6, 2006
    Not really. A single PCIe 3.0 lane can transfer data at 985MB/s while a sata III device can only transfer 600MB/s. Even if you had a PCIe SSD or RAID controller, you're still limited to how many lanes the device was designed to use. So if that's 4x, then it doesn't matter if the CPU has 20 lanes or 48, your device will still only use 4.
  33. thesmokingman
    thesmokingman [H]ardness Supreme
    4,831
    Nov 22, 2008
    Whoops, voted 6800K but meant 6700K. I think its time for me to move on from this 3930K and RIVE, massive rig to something current and more streamlined. I'm looking at the 6700K for the hevc, quick sync, all the goodies I've been missing, tears up. I've been out of the upgraditis for a while thanks to the longevity of the 3930+RIVE.
    I'm unsure of what's a good memory to go with. I was looking at the gskill trident 3600mhz or 3733mhz. Is that a decent choice?
  34. NeeqOne
    NeeqOne n00b
    3
    Oct 9, 2015
    I am thinking of grabbing a very good i7 5960X or i7 6850K based on how well it overclocks. I am not in a hurry at all.
  35. UnrealCpu
    UnrealCpu 2[H]4U
    2,736
    Jun 20, 2003
    what are you guys using these processors for because a skylake overclocked to 4.7-4.8 will beat the x99 v3 cpus haswell-e in gaming?
  36. drescherjm
    14,424
    Nov 19, 2008
    Although I am most likely not purchasing the 6950X processor any time soon my primary interest for that would not be gaming. It would be for the type of work I do in the day job (medical imaging research). Some research algorithms take hours for a single case and require both good single threaded and also good multithreaded performance.
  37. thesmokingman
    4,831
    Nov 22, 2008
    Some kind of professional work where time equals money I would suspect. That would also depend upon whether their apps are heavily threaded or not, and I hope they are.
    The big chips also get a huge advantage in physics scoring in 3dmark family of benches which makes them ideal for serious benching, especially multi gpu benching.
  38. tangoseal
    tangoseal [H]ardness Supreme
    7,415
    Dec 18, 2010
    meh none of the above. My 3930K at 4.5ghz is absolutely untouchable by any game of current tech. No need to upgrade.
  39. UnrealCpu
    UnrealCpu 2[H]4U
    2,736
    Jun 20, 2003
    hate to say it to you but you are misinformed
    skylake runs better for games
  40. tangoseal
    7,415
    Dec 18, 2010
    LOL @ your comment. This is not a question of being informed or not. This is my opinion. End story.
