What video card? I've been out of the loop a while...
Discussion in 'Video Cards' started by virtualleader, Jan 5, 2017.
  1. virtualleader
    virtualleader Limp Gawd
    162
    Jan 23, 2011
    I am lookign for help. I am a gamer, first however I recently started doing a fair amount of videography mainly in Adobe Premier. My issue is Premier does not like 690 because it essentially only sees 2gb of mem not 4gb. Also, it's been a while since I was on buy/sell forum, any idea what the 690 might worth? Love the card but I am feeling underwhelmed.
    Should I go with the 1080ti? Titan (I dont really want to drop a $1000)?
    Current Build:
    i5 2500k o.c. 4.6ghz
    Asus p8p67 pro
    32gb Mushkin Blackline
    EVGA GTX 690 SIGNATURE
    Crucial M4 512gb boot drive & 2x 1tb WD Black Raid 0 & 120gb SSD scratch disk
    Sound Blaster X-Fi Titanium HD
    Corsair H50 CPU cooler
    corsair tx750 PSU
    Dell U2711 2560x1440
  2. Krenum
    Krenum [H]ardForum Junkie
    12,912
    Apr 29, 2005
    I would upgrade your core components first before a new Video card. i7 6700k 16 or 32GB of DDR4 would be better suited for Adobe than a new video card & that 690 would still play the games you want to play paired with your new system.
    Another option would be to sell the 690, probably get 200-300 for it. Use that money to put toward a new system upgrade, & get a 1070 or 80. It'll take some shopping around but I bet you could build a new system for under $1000, way under if you sold you current components. Check Microcenter, they always run good deals on CPU/Mobo combos. Also, if you havent shopped at Jet.com & are a new member, you can get 15% off your first order with them.
    1080ti's haven't been announced yet.
    Nebulous and Armenius like this.
  3. virtualleader
    162
    Jan 23, 2011
    Well, I was rather trying to avoid a whole new core system. Premier CC offloads a ton onto the vid card now days. If you saw my post I already have 32gb ddr... yes DDR3 but with Premier it's more quantity than speed. I supposed I could find a new i7 for it... that's a thought but really worth it? Premier does a lot of CUDA offloading.
  4. Krenum
    12,912
    Apr 29, 2005
    Well, in that case, get a 1080. Like I said, if you order from Jet, you can get 15% off from them, if you choose to go that route. I was thinking more along the lines of having Hyperthreading for Adobe or get the best of both worlds if you part your original system out to cover some of the cost of your new one.
    Your system as it stand would probably be worth around 600-700 dollars, that would buy you a new system, and you'd still only be paying for a video card.
    Armenius likes this.
  5. Schmave
    Schmave [H]ard|Gawd
    1,724
    Jan 2, 2001
    A 1070 would probably be plenty fast for Premiere acceleration at this point. The 1070 will also do well with your 1440p monitor and save you some $$ over a 1080. I don't know if it's still true but the Adobe products that include GPU acceleration tend to work better on Nvidia cards since they originally started with CUDA development.
    Plus, for gaming, your 2500K might start to limit a 1080, but probably not a 1070 as much. FWIW I'm running a 2500K at stock clocks right now and haven't had problems in the games I play yet.
  6. virtualleader
    162
    Jan 23, 2011
    Fair point on the proc limiting the card... 1070 is likely to peak it out. I wonder if I can find a 3770k cehap enough too to be worthwhile... perhaps...
    Thanks for hte 1070 idea.
  7. tikiman2012
    tikiman2012 [H]ard|Gawd
    1,186
    Dec 16, 2009
    Just registered & can't get the 15% off at Jet.com to show up.
  8. Krenum
    12,912
    Apr 29, 2005
    Check the front page. Use WELCOME15
  9. Tahoe916
    Tahoe916 Gawd
    602
    Jan 11, 2007
    For what its worth, I do a lot of Premiere and Photoshop, and the video cards do help, but not a ton. I got a much better boost from upgrading my CPU to a hexacore Xeon than I did from using a newer NVIDIA card. In fact I ended up returning the video card and just going with the CPU upgrade because it made such a little difference for me.
  10. RazorWind
    RazorWind 2[H]4U
    2,983
    Feb 11, 2001
    Unless you're overclocking the hell out of it or only play old games, most games are likely to be CPU bound on a 2500K with a 1070 or 1080. I don't understand why everyone thinks this isn't the case - it pretty obviously was, in my case, over a year ago, even with "just" a GTX 970.
    I agree with "upgrade everything" and "get a 1070."
  11. tikiman2012
    1,186
    Dec 16, 2009
    Keep getting "No items in your cart are eligible for WELCOME15" when I try to use it with a video card.
    What am I supposed to be looking for on the front page that I'm missing?
  12. Kev7274
    Kev7274 n00bie
    12
    Dec 27, 2016
    Not just you. I couldn't get the code to work on a GTX 1070 or an Evga PSU. Certain restrictions are apparently applied to using the code.
  13. Krenum
    12,912
    Apr 29, 2005
    Hmm, thats odd, wasn't aware of any terms or conditions on the items that would receive the discounts. All the codes I've used , even the one for signing up have worked.
  14. tikiman2012
    1,186
    Dec 16, 2009
    Now this is showing up on the cart page.
    15%
    OFF
    your first 3 orders
    UseWELCOME15at checkout
    on your first order to qualify.
    Offer applies to the Grocery, Household, Health & Beauty, Baby and Pet Supplies categories.
    Min. order $35. Max. discount $30. Expires 2/1/17. See details"
  15. Immolation1991
    Immolation1991 [H]Lite
    119
    Feb 23, 2016
    are prices expected to drop once Vega gpus hit the market or is it unlikely?
  16. SvenBent
    SvenBent 2[H]4U
    2,058
    Sep 13, 2008
    Because it depends on the game. you can make a blanket statment like 2500k will bottleneck a 970 since it higly depending on the workload of the game and settings.
    my 3770k at 4.4 ( crappy mobo) was bottlenecking my 970 under doom 2016 until i switched to vulkan.
  17. Maddness
    Maddness Gawd
    776
    Oct 24, 2014
    I would think so. But it mainly depends on how well Vega performs.
  18. RazorWind
    RazorWind 2[H]4U
    2,983
    Feb 11, 2001
    Well... obviously. But everyone likes to make these blanket statements about "Oh, the 2500K is still more than enough CPU..."
    Maybe it is if all you play is CS:GO or something, but for non-esports games, my experience is that that hasn't been the case for a while.
  19. SvenBent
    SvenBent 2[H]4U
    2,058
    Sep 13, 2008
    I totally agree.
    But i think the reason is that people just look at total CPU usage and sey "hey it only using 50% so im not CPU bottlenecked", and not taking multicore/multithreading into considerations. i see that very often sadly :(
  20. DocSavage
    DocSavage 2[H]4U
    2,511
    Dec 18, 2002
    Kyle just did a comparison between a 2600K and a 7700K and it was 30% faster at best. Do what I did and get a 1080 or a 1070 and you'll be fine.
  21. horrorshow
    horrorshow 2[H]4U
    3,899
    Dec 14, 2007
    Yeah, sell that 690 while it still has value and buy a 1070.
