Protoform-X
- Jan 30, 2002
Cisco 1721 on both sides. Yesterday users started reporting problems accessing servers over the point to point in either direction. There were some problems with the T1 line that the ISP claims have been repaired. Is there a problem with my equipment, or is there still a problem with the line? I see a mess of input errors report on the PHX router and they seem to be streaming in at a steady rate. Not really sure what they might indicate.
Code:
PHX#show int s0/0/0
Serial0/0/0 is up, line protocol is up
Hardware is GT96K with integrated T1 CSU/DSU
Internet address is 10.0.0.1/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 207/255, txload 1/255, rxload 5/255
Encapsulation PPP, LCP Open
Open: CDPCP, IPCP, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 20:44:14
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/16/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
5 minute input rate 32000 bits/sec, 4 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
260688 packets input, 59016507 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 4 giants, 0 throttles
142445 input errors, 142445 CRC, 49173 frame, 24138 overrun, 0 ignored, 830
51 abort
177939 packets output, 61160438 bytes, 0 underruns
0 output errors, 0 collisions, 118 interface resets
0 output buffer failures, 0 output buffers swapped out
9 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Vegas#show int s0/0/0
Internet address is 10.0.0.2/30
reliability 255/255, txload 3/255, rxload 1/255
Last clearing of "show interface" counters 19:01:50
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Conversations 0/15/256 (active/max active/max total)
5 minute input rate 1000 bits/sec, 3 packets/sec
5 minute output rate 19000 bits/sec, 11 packets/sec
161503 packets input, 54683791 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
297097 packets output, 124032257 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
1 carrier transitions
