CaptNumbNutz
- Apr 11, 2007
I'm about to attempt to sleeve for the first time. I will be doing custom wiring for my rig.
I have no clue which size you use for each size wires.
I also don't know what size heatshrink I should use to cover the sleeving and the wires.
I have to sleeve and heatshrink the following:
- 24pin main power cable (18 gauge wires)
- 4pin molex, sata, and ATX 12v cable (18 gauge wires)
- 3 pin fan cables (26 gauge wires)
What sizes do I use?
Anyone know any good tutorials?
I will be buying my wires, sleeving, and heatshrink from here:
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=44
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=156
