Blackstone
- Mar 8, 2007
Long story made short---two days ago my uber expensive X99 build with 5930k just crapped out when I set bios to optimized defaults (go figure). Probably the mobo fried. I think it was on the fritz for a while. I tried everything to fix it but no dice.
So I did the easiest thing--NEW BUILD.
Coffee Lake 8700K and Asus Rog Maximus Hero Board. Was able to salvage power supply, ram and case from old system. Runs like a champ--better than the X99 Haswell-E ever did. Just rock solid.
I set MB to XMP and booted. That is all I did.
Should I even try pushing this beastly chip? I have a brand new Noctua DH15 on it and temps are in the 50s in Battlefield 1. Also, the Silverstone FT01 case is a wicked CPU air cooling case. 180mm fan dumping cold air on the heatsink and mobo from above, 120mm noctua fan spitting it out the back.
My understanding is with Turbo Boost I should be getting above 4Ghz on all cores during gaming. Which it seems to me should be FINE. I am not a benchmarker, just a gamer.
GTX1080ti graphics.
Should I just leave it alone and let XMP do the work or should I try and get more out of this chip. I figure with the Noctua I am safe to experiment, a bit..What do you think?
GTX1080ti graphics.
