Im going to build a waterblock that will use 3 sandwiched plates. 1/4" copper plate, 1/2" aluminum center channel plate and a top 1/4" aluminum top plate.
It will end up held together with probably 8 screws but I think more would be needed to make sure it doesn't leak.
Silicone type stuff I hear tends to get "Enflamed" as it absorbs water and thus becomes a cooling/flow problem. Most epoxies from what Ive seen don't handle water well either.
Is there any good sealant out there that I could maybe goop on before everything is bolted together?
